Fault code f14 whirlpool duet ghw9250mw2 - Washing Machines
  • comet12345 Oct 20, 2008
    THANKS FOR YOUR HELP VERY COSTLY BUT WILL FIX POBLEM. HARRY
  • books6 Apr 11, 2009
    Thanks for this info my repair man was charging me 125.00 a visit when it was getting clogged to unclog it. I had asked him if I could fix it and he said it was too difficult. I was never here when he did it so I did believe him until now. I am glad I jumped online to research. My kids just throw in the laundry and dont check for things and it was getting expensive. Then i checked the ccu and one of the connections was loose so I solved that problem. I say thanks a million times over for this will save me money.
    Scholar:
  • 64 Answers
Ok first you need to remove the front cover below the loading door... (Should be 3 Phillips screws on the very bottom). You will see a white cap in the very center. You are going to need a bowl to catch some water and probably some debris when you remove it....Make sure you get all the debris (coins wrappers...ect...) out before you put the cap back on the drain...Then try to run a normal cycle again. You can always run the diagnostic program that is found in the manual which is also located behind that front bottom cover if the normal cycle doesn’t go all the way through…I also had to replace the CCU (Central Control Unit) due to the fact that I was still getting the F14 & a F11 error… If you are hearing a faint clicking sound coming from the top back (before you get the F14 error) then I know for sure you need to replace the CCU... I will give you the link to the site where you can buy it....If you have any type of home protection plan I would just call them and pay the service fee (mine is only $50)....its going to be a lot cheaper that way…. If you decide to buy the part and do it yourself make sure you get the model number off the CCU. The top cover is just as easy to take off...the CCU will be located in the center on top and will also be white in color... Please make sure the washer is unplugged before you remove any covers….I hope this helps....please let me know....and here is that link to the website http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059617&PPStack=1
Posted on Oct 20, 2008
Fault 14 on my washing aa 10kg one any one know the problem ? help holly
Posted on Sep 21, 2010
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Code F1, does not stop filling, water pours out of soap tray
Are you sure it's not an F/H error?
The F/H code means the unit isn't detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. Part link to the flow meter==> http://www.repairclinic.com/PartDetail/Flowmeter/1381535?modelNumber=GHW9250MW2
If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems.
Read more: Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2006/04/09/whirlpool-duet-kenmore-he34-washer-f11-and-fh-fault-codes/#ixzz1GVNXRInv
Get appliance parts at http://parts.fixitnow.com
Mar 13, 2011 | Washing Machines
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: what does the F14 error code mean?...
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer keeps flashing f14
"F14" is an EEPROM error on the Central Control Unit (CCU). The CCU is the main computer for the washer. This error is normally caused by a power glitch and can be cleared by unplugging the washer for 2 minutes. If the error code reappears, the CCU has to be replaced.
Jul 12, 2009 | Washing Machines
NEW CCU for Whirlpool Washer
I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Code F14
Greetings pattiprem,
This error message can sometimes be caused by a power glitch. Try unplugging the unit for 2 minutes to see if this fixes the error. Another cause can be a problem with your Central Control Unit.
Thank you,
Dorothy
Go Ahead. Use Us.
Jul 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
3,078 people viewed this question
Top Washing Machines Experts
