Question about Toshiba 57H82 57" Rear Projection Television
How can I correct Toshiba TV anti-glare coating
  • 3 Answers
Take the screen off the TV and remove the gray tinted plastic panel, that may solve the problem
Posted on Dec 05, 2008
S.N RS051DL103300. I just want to know if you sell a protective screen that is anti glare?
Anon. Protective screen that is anti glare, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NuShield Anti glare Films In TV Room Design
FAQ Answers for Questions on our TV Screen Protectors
TV Screen Covers ScreenProtek
How to rid your HDTV of reflections
May 26, 2016 | Televison & Video
Reflection off of screen
Plasma TV's are known for their glare and reflection issues, you can still fix it by buying a third party anti-glare filter and applying it on your television. For example, "ViewGuard" makes filters that goes up to 65" in size. It is not cheap though, depending on the size of your television.
Of course, the best solution is to adapt your room accordingly. If the glare is caused by the sun light coming from the windows, installing curtains on your windows or moving your television to a better spot is a very effective way to reduce the glare and the reflections on your television.
If the glare is caused by the room's lights, the best solution is to install ceiling spot lights with a dimmer.
Hope that helps!
Mar 19, 2014 | Samsung 51 Class Plasma 1080p 600Hz Smart...
Need to replace a cracked screen, where can i find one or have one made?
If JVC does not have it you are likely out of luck, if the outer protective screen it might be possible to have a piece of plexiglass cut and put in but the original was anti glare coated so you would likely have a glare issue.
Dec 14, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Picture has glare
The outer screen has a anti glare coating--direct light on the screen will cause some glare.....
Dec 03, 2012 | Mitsubishi WD-60638 DLP TV
White out correction fuid on lcd tv screen
Use no cleaners with chemicals in them--permanent damage will happen---there are special cleaners and towels for this--not sure where you are but call one of the large electronic stores---they usually have and sell cleaning kits for this type of set. When cleaning be patient and do not rub too hard and go slow.
Most of the screens have a anti-glare protective coating and can be damaged easily.
Nov 07, 2012 | Insignia Televison & Video
I have the newest version of this plsma TV. It is one month old. I tried to clean some areas of the screen with a micro fiber cloth and a dab of windex in 1 corner of the cloth, not realizing that the...
You have damaged the outer protective screen. Only replacement will fix. Water only on a damp cloth should be used to clean. However, the outer screen can be changed. Since the tv is almost new you will have to contact Samsung at through customer service at 1-800-627-4368 9AM to 8:30PM Eastern time. When changing the outer screen be sure to never touch the inner screen after removal. You have to take the back off the set to get to the screws holding the baziel or "plastic frame" to remove the outer screen. I have never taken a screen off of a set that new so I advise you exercise patience when removing. Have the product code ready for customer service to locate the proper protective screen. And serial number.
Oct 23, 2011 | Samsung PN64D7000 3D Plasma TV
What is the best way to clean a 46" LCD Toshiba TV
You do not want to use any harsh chemical or anything in excess. What I use and recommend is simply water and dish soap such as ivory. Use clean lint free paper towels or cotton or soft fabrics. You put a drop or two of detergent on a damp towel.You gently wash the screen then wipe it dry. The towel needs to be damp but not enough so that you get any running water.You may need to do it in small sections. If you use too much soap you get streaks. If that happens just get another damp piece without soap and go over and then use the dry to wipe the screen dry. The soap takes off anything without harming the anti-glare coatings on the screens. The wrong type of alcohol or a harsh cleaner can strip these coatings off or damage the plastics. Dish soap and water is very safe dirt cheap and found in the kitchen usually. ;-]
Sep 02, 2011 | Toshiba 46SL417U LCD TV
Toshiba 57H82 57" Rear Projection Television Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
