Question about Toshiba CX32G60 32" TV
Power on but no picture or sound
Stopped working. When power is turned on, the relay clicks, the LED power light flashes slowly on and off. The screen is black, no sound. When the power it turned off, the screen lights up white in the center as the picture collapses. This happened once before but then the problem went away with no obvious cause. Also removed power and restored it with no result. Suggestions appreciated.
  • ben shuler Jun 24, 2006
    Forgot to say that I checked the cable box output with another TV and the other TV worked fine. With the screen black, I cannot tell if it is tuned to channel 3.
    President:
  • 3,130 Answers
Your problem is from the power regulator IC . Its an str type and has to be an original from tosiba or its parts distributors. Now you may have caused more problems as alot of peeps do trying the set over and over again thinking Oh the set will rest its self.. Nope sorry sir if a set goes bad and you try it once , and it dosent come back on . Its time to seek a repair person to repair and troubleshoot the set for you UNless your a technician? If your not Dont try to repair a tv as these have non serviceable parts for the consumer to replace! And can bite ya in the butt, if your not carefull. We techs cannot teach ya overnight how to fix something. Only assit and to point ya in the right direction. Good Luck
Posted on Jun 24, 2006
SOURCE:
Panasonic TC-42PX14 wont turn on power light flashes 1 time
You may want to shop for that board or at least consider removal of the HDMI socket in question---tested for shorts there I presume?
Nov 05, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
No picture on mu LG television.
Try the old flashlight test, turn off the lights in the room. Turn on the set and flash a bright flashlight on the screen. Do you see the image or is the screen totally black?? If you see the image, then most likely you have a backlight problem. Verify that you have 24V on the power supply for the inverter
May 20, 2012 | LG 19LH2000 19 in. TV
LA40F81BD power light flashing and clicking sound
Likely a relay if it has one--if problem has slowly been getting worse it could be caps on power supply board (usually happens when set around 2 years of age)
Mar 18, 2012 | Televison & Video
No picture red led power light flashing on off
i got the same problem in Samsung LNS4051D, it would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. It need to replaced/repair power supply. after that it works fine, but it need to handle technically...
hope it helped, if so do rate the solution
Nov 22, 2010 | Samsung LN-S4051D 40 in. LCD Television
No picture, when powering up the light will turn yellow, them the t.v powers up and can hear sound but no picture, and then hear a click and light flashes green.
First turn on,do the power LED light stable?Few sec.Power LED and LED OPC flashes?This very common on Sharp tv,tries power off/on at 4 or 5 each time it flashes,well power up have backlight on and it work.After this doesn't work than ur Tuner Signal board it dead.
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Toshiba 36HF71 has sound but no picture
Same problem with mine. Relays click, sound, no picture and a flashing power LED. I finally found a schematic online. I went through the high voltage circuits and found the power transistor 2SC5570 was shorted out. There is also a pico fuse in that area but my was not open. I replaced the transistor and prayed the flyback transformer was not shorted. It wasn't, I'm watching my old 36" right now. Not a bad fix (17.00) bucks. Wonder what a service tech would have charged ;)
Jan 02, 2009 | Toshiba 36HF71 36" TV
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
