Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag washer has problem dripping water into drum.
When the machine finish washing, water dripping into drum that makes drying difficult. where the dripping leak from and how it can be fixed?
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
Krazytech
  • 725 Answers
SOURCE: WAsh machine drum bearing removal
check out the tommy tool on youtube .it will show you how to do it even if you don't buy the tool...
http://www.youtube.com/watch?v=F3Wrq6Yxra8
let me know krazytech
Posted on Aug 13, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Maytag MHWE400WW01 fills with a small amount of water when not in use
Selenoid valve leaking. Could be a rubber washer or complete valve or very low water pressure.
Dec 08, 2013 | Washing Machines
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Internal leak on a kenmore top load washer
Yes, very likely is a bad water inlet valve allowing water to leak past it into the drum. Really not a difficult repair with a little help.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 13, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
When the washer finishes the spin cycle and I open it up to remove the cloths, the water continues to drip into the drum. What do I need to do to repair this problem.
It sound's like the water inlet valve is stuck open, it's located at the back of the washer, the cold and hot water hose's connect to it, you may need to replace it with a new one to fix the drip.
Apr 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water drips out of front door
There does obviously need to be water in the drum to wash or rinse the clothes, however it may be the water level is now higher than normal , check for any blockages and check any drain pump filter.If all o.k. it may be the door seal is leaking .If under g/tee call maytag for repair
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
When washer finishes there is a dripping of water inside unit
What has happened is you have sand in your water valve from your water. This pluggs the water valve and also sticks it open so when the water valve shuts of there is still a small trickle of water coming through the washer. Replace the water and it will fix the problem (no way of cleaning the inside of the valve.) Replace water valve.
Nov 24, 2008 | Maytag Washing Machines
Maytag atlantas top loader water keeps dripping from top of drum
Your water inlet valve is probably leaking by. If the water pressure is too, or if there is sediment build inside the valve, sometimes the solenoids will not close properly. Try cleaning the valve to see if this helps. If not, I would recommend replacing it. Depending on which valve you have, repairclinic.com has two listed for this model washer for $20 to $30. Let me know if this helps, or if you need further assistance.
Apr 23, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
306 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
