C13 means the deck cannot read the minidisc table of contents for some reason. Since you have no disc in the deck it probably means the laser head is out of allignment or just plain worn out.
I often see MDs being sold for parts, but you need to know the fix is usually cost prohibitve. Most likely the laser assembly in your deck is bad and will cost too much to replace. MD's are more complex than CDs and are optical/magnetic using a laser to read and a laser + magnetic head to record on the discs which are read/write many times.
SOURCE: Giving
HELLO
Strange one this! C13 is a protection error, but the machine should play discs that it recorded. It could be that you may have to give the laser lens a good cleaning by using a cotton bud and a little isopropyl alcohol. You will have to remove the cover to do this and when you clean the lens use a gentle circular motion.
Don't soak the cotton bud when you do this but if you do, remove any excess liquid. Leave it for about 5-10 minutes then try the machine again.
If there is no change, then you will have to take it to a service centre in your area.
GOOD LUCK!
SOURCE: Sony MDS-JE480...Inserting disc..C13 error READ
The
c13 error means that the player is unable to read the table of contents
(TOC) on discs any more.If it's an occasional error then you can try
switching to TDK blanks as they seem to be easier for flaky players to
read, but if it's happening regularly to all discs then your machine is
unrepairable due to a total lack of spare parts.
On the plus
side, there are millions of MD units now lying unused as folks have
moved on from them and as they're mostly worthless people don't
generally bother with trying to sell them. Almost every piece of MD gear
I own has come free of charge via my local FreeCycle and Freegle
groups. Whatever you do, don't buy a used player from anyone: they're
all getting on now and the TOC error is an age-related fault which may
occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org.
The site is hosted but n longer maintained though so some information
is out of date, but it's still the most comprehensive source of free
information about MD available.
Sorry here's probably no hope for
your MDS-JE480, but I hope that my reply has given you a practical
alternative means of solving your problem.
SOURCE: disc error displaying on je500 and read error c13 on je330 model
The
On the plus
occur at any time.
Sorry there's probably no hope for
your players, but I hope that my reply has given you a practical
