Question about Motorola Mobility V710
Doesn't turn on!!
My Motorola V710 was working fine until the battery died. When I connected the charger the main screen just began to flash in period of 1 second showing me the HELLOMOTO startup screen. The phone doesn't seem to charge and doesn't turn on either. I don't know WTF happened, please tell me how to fix this. Thanks. -No water damage -Battery works fine -My charger is - CH600 Travel charger -Tried a different charger
  • 1 more comment
  • hitman345 Dec 12, 2007
    ive got a sony ericsson w550i and i tried to send something off the pc to my phone. i used the cable of a later model sony ericsson and now when my phone turnson it stays on the sony ericsson menu and doesnt proceed. what shall i do
  • shelbycsx Dec 15, 2007
    Exact same thing verbatim happened to me. The battery died. I pushed the power button and it started to start up and played it's little motorola startup chime. As it was starting, I plugged it into my car charger and it started blinking. It almost seems like the operating system is confused when trying to start but this is only a novice theory. Please help.
  • accordionman Jan 11, 2008
    I had the same problem. The phone has been workinh flawlessly until one morning after having it on the charger, I found it flashing the hellomoto screen every second and doesn't turn on. Took it to a cel phone expert who found nothing physically wrong with it. No dirty contacts, broken wires , nothing to indicate a problem other than maybe a software problem. He had taken it completely apart and then put it back together. I am very disappointed since it wasn't a cheap phone. Does Motorola not care about it's reputation??
My phone has the same problem, and i heard you can't really do much for it. I tried a new battery and like charged it, but someone told me it was something wrong with the wiring... good luck.
Posted on Jan 04, 2008
I have the exact same problem with my E815 Motorola...only had a month or two, forgot to charge and battery went dead. Now moto screen comes on for about a second and dead? Try to get to boot loader, same thing...dead.....Bob
Posted on Feb 15, 2007
  • 175 Answers
Have you looked at the chager and see if its the original if not thats whats causin it.
Posted on Jul 09, 2006
  • 513 Answers
You need to try and get into the boot loader to see if you can flex/flash it from there. a new flex should solve the problem, unless there is physical or water damage to it. It could also be a defective battery. Are you positive the battery works? Did you do any kind of upgrade on the phone? played with it's firmware? On flashing - http://wiki.howardforums.com/motorola/index.php/How_to_flash_with_RSD_lite Flexing is done the same way Good luck
Posted on Jun 27, 2006
How do you turn on a motorola v710 after is has charged
push green button and hold on for a couple of seconds.
Jan 03, 2015 | Motorola Mobility V710
I let my phone battery die yesterday and now when i try to charge it it says that the charger is attached; but when i try to charge it and turn it on it only goes to the main motorola screen with the...
yes of course, you need a new battery.
when you get this battery, also buy a universal charger.
do not insert the battery into the phone until you charge it for 3 hours with the universal charger.
after that the phone will work very fibenluis_14.jpgne.
Jan 27, 2011 | Motorola Mobility Clutch i465 Cell Phone
I have a Motorola V710, it will not power on but the screen blinks when plugged in to charge, what's wrong?
The batery may not be holding a charge anymore, try removing the battery and clean the contact's, if that do'es not work the battery may need to be replaced.
Apr 18, 2009 | Motorola Mobility V710
V710 Motorola will not power on but screen blinds off & on plg in
I think there is some problem @ your battery. Change the battery & check whether the screen works or not if it ask for unlock code you can get the code from motorola code
BLUETOOTH WILL NOT CONNECT
its possible its your friends phone, make sure your bluetooth is completely on by going to "turn on blutooth" first then make your phoen discoverabel and try it with soemone elses phone. it doesnt matter that it flashes, as liong as it as the lil blue tooth sign on the top of the screen, only problem with that phoen is its supports limited files throguh bluetooth Bluetooth Supported Profiles: HSP, HFP, DUN
version 1.1 / DUN profile carrier-dependent
May 30, 2008 | Motorola Mobility V710
Motorola v710 cell phone
Is the battery lithium -ion? If not, you have an older generation of battery.
Having mentioned that, some batteries need an introductory "conditioning period". Continue your excercise of charging and draining (dont drain too too low) and hopefully you will start seeing some decent longer lasting charges.
Hope that helps!
Feb 08, 2008 | Sony Ericsson W200i Cellular Phone
Charging problem!!! PLEASE READ!
as i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
Feb 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola L6 erratic ability to turn on
you need to take the phone to a mobile service center and have them reflash the firmware on the phone and that will correct the problem
Dec 26, 2007 | Motorola Mobility L6 Cellular Phone
Battery won't charge
I have the same phone and it flashs every now and then when its charging but it charges and works fine. Is yours charging?
Jun 25, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola V710 won't charge
While not a fix for this problem, what I have found to work nearly every time is to set something slightly heavy on the charger prong where it enters the phone. Turning it over and resting the prong on a book also allows it to make the necessary contact. It has lasted me for two years; one year charging just like that.
Dec 16, 2006 | Motorola Mobility V710
Motorola Mobility V710 Logo
377 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
