I'm guessing there are one or more fuses and probably a relay involved. Does anybody know the location of the fuses/relay for the rear window defogger? (the owner's manual isn't specific about even the fuses).
Thanks in advance
There are 3 fuses that control the rear defogger, and 1 relay
The fuses are: 10 amp HEATER, 10 amp MIRROR-HEATER; under the dash
The 30 amp DEF fuse is in the fuse box under the hood
The relay is the DEFOGGER relay, which is on the back side of the fuse panel under the dash
Also, check for a loose wire on the defroster grid (on the back glass), this is the most common problem.
Liftgate module (LGM)/endgate module (EGM)
Rear window defogger grid
Rear Window Defogger Operation (With LGM)
Battery positive voltage is supplied through the LGM 2 fuse to the LGM for the rear window defogger system. When the rear window defogger switch is depressed, the HVAC control module illuminates the rear window defogger indicator, and sends a class 2 message to the LGM to enable the rear window defogger. The LGM enables the rear window defogger by allowing battery positive voltage to the rear window defogger.
When the rear window defogger switch is pressed for the first time, the defogger cycle lasts 10 minutes. Further operation results in 10 minute defogger cycles.
DTC B0283 Electric Rear Defrost Circuit - do you know what DTC'S - diagnostic trouble code's are ?
Circuit Description
The liftgate module (LGM)/endgate module (EGM) monitors the voltage level on the supply voltage circuit of the rear window defogger. The LGM/EGM test the supply voltage circuit of the rear window defogger every 160 milliseconds. With the rear window defogger inactive, the supply voltage circuit of the rear window defogger will have no voltage present. With the rear window defogger active, the supply voltage circuit of the rear window defogger will be near system voltage.
2001 Sienna's rear window defogger wires have come undone from the window (under the plastic molding) must we use some type of specific adhesive?
Thanks
