Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi wd 52525 Problems, but no blinking lights.
When tv was turned off, everything was working fine. Turned tv on next morning and, Ant.1 showed a black screen with white dots, and computer garbage (It wasn't just static, you can tell it is computer generated lines), moving around and was colored green,
The other devices, (ps3 and vcr) had blue screen with a basketball sized ghost floating around in the middle of the screen. Sometimes, audio partially works on ant. 1. I can select demo mode and the picture comes in almost perfect, except for the floating ghost is still present.
There are no flashing lights on the front panel, just the one solid green light.
So, Neal, would you have any dissassembly diagrams or other info that might help me do the repairs myself. My e-mail is Boss51@Atlasok.com. Thanks for any help you can give.
5 Suggested Answers
  • 6 Answers
SOURCE: Flickering blue picture
I finally got around to dismantling the TV. This is no mean task. The chassis is tethered to the rest of the set my over a dozen wiring harnesses and a few of these cannot be disconnected near the chassis but instead require removing the “right support” near the air duct and taking the shield off the lamp ballast. Once the chassis assembly is out, it is a further significant task to disassemble it to get at the various PWBs (POWER, FMT and DM) having the suspect caps. I’m sure reassembling everything will be a fun job!
I have not yet had a chance to fix and reassemble but I wanted to post this no as I’m not sure when I will get around to it.
I did find six of the fourteen known-problem caps to be visibly bulging -- both 3300s and two of the four 1000s on the PWR PWB plus two of the four 1000s on the FMT PWB (see photos below). Ironically of the four 1000s on the DM PWB, which I have heard are the most common to go bad, were bulging and I considered skipping these as the DM it is the toughest board to extricate from the chassis, however I figured I had come this far and I would just as soon replace all twelve 1000 uFs as the parts cost $0.23 and I really never want to have to do this again.
If I had to bet, the two 10V 3300uF caps on POWER board, which were actually leaking black goo, are the actual culprits, but with four of the 1000 uFs also bulging it is probable only a matter of time until they failed as well.
Here is the POWER PWB with the known-problem caps (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) highlighted:
here's the FMT PWB with the known-problem caps (C8F19, C8F21, C8F22 and C8F27) highlighted:
and the DM PWB with the known-problem caps (C81A2, C81A3, C81B3 and C81B4) highlighted:
Here are close-ups of the bulging caps (C9A37, C9A38, C9A52 and C9A62) on the POWER PWB:
And here are close-ups of the bulging caps (C8F19 and C8F27) on the FMT PWB:
Posted on Feb 16, 2008
  • 179 Answers
SOURCE: mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to www.tv-techs.com
Posted on Jan 12, 2009
MNfisherman
  • 11896 Answers
SOURCE: green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
Posted on May 06, 2009
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
Red "lamp" light was on
t is more than likely your television has had a lamp failure. Part number 915P020010 is the right part for your tv. Remove the lamp, your instruction book will tell you where it's located. Check the anode of the lamp, if fracture find a lamp on ebay vendors. Try niosales.com They are my trusted vendor for new lamps.
Jul 11, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-65831 one night worked fine next day nothin..
If you hear a whining noise, the odds are it is the color wheel, the bearings are bad in it and will need to be replaced as a whole unit, kinda pricey, my suggestion, sale the bulb and all boards in it and which should fetch about 400+ and invest in a new TV, a color wheel is pricey unless you can find a deal
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd52525 problems
Oct 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Mitsubishi WD-52525 52 only 2 1/2 years old
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 15, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Im seeing double on my 36inch Mitsubishi projection!
Do the colors seem "separated" somehow?  Sounds like the projectors might have become misaligned. Has the TV been knocked by pets/children/spouse?
Nov 26, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
