Sony plasma 50 inch has lines in the middle of screen
Sony plasma 50 inch has lines in the middle of the screen
i have checked different sources of video it is on the tv
  • yacoobnoor Oct 20, 2008
    bad plasma means not repairable ?
Thank you your answer is appropriate i am sorry if i could not understand the
answer thank you once again
Posted on Oct 21, 2008
  • 320 Answers
It sounds like a bad plasma panel but I would have to see a picture to be sure
Posted on Oct 19, 2008
  • Any Guy
    Any Guy Oct 20, 2008
    How was this in inappropriate response? A qualified technician can diagnose a bad plasma panel by viewing the symptom or by seeing the plasma panel! If you are nhappy that you have a bad plasma panel, please don't take it out on me!
  • Any Guy
    Bad panel means the cost of repair would probably exceed the value of the unit. A bad panel can show one or more rows of pixels stuck on, sometimes with a color associated. Also, a bad panel driver can cause this condition. Sometimes, it is merely a connection between the panel and the panel driver circuit board. Those problems are considerably cheaper than a bad panel. If you have a bad driver board or a bad connection the repairs would be worth the investment. If this information is helpful, I would appreciate if you would change my rating. Thank you.
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
I have a sony plasma 50 inch i am getting a few lines in the middle of screen and they are there when i turn on the tv even though i do not have the cable on
Are they very thin vertical lines? If so, you most likely have a bad plasma panel. A picture would help to confirm the diagnosis
Oct 19, 2008 | Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
Mar 10, 2008 - Posted on Mar 17, 2012.
Red line down middle of television
Try putting a litte pressure on your screen where the red line is,if it goes away then check for a loose pin connection where that line was...
Sep 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
Horizontal lines on plasma
If the line is exactly in the center of the image then you might have a bad panel most like you will need to check the y or x boards make sure they are connected firmly, these are the thin boards on the edges that connect to the actual screen disconnect them and use an eraser to clean the contacts then reseat them it should work other wise you will need a very expensive repair that willl involve the x and possibly the y driver boards.
Jan 02, 2010 | Hitachi 50V720 Television
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Black line down screen
hello, your tv has either the lower or the upper buffer defective, worst case scenario is the screen but only a tech with the skills can determine wich one is bad.
good luck
May 20, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Sony Plasma PFM 50 ci black screen
. Check blink of leds
check the 5 v control voltage.
check Ysus and Zsus board.
check Voltage sc, Vs and Voltage a .
Yareth De Matos - Venezuelan -
Mar 28, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
