Question about Dell Dimension 5100 (D51L1) PC Desktop
System turning completely off for no reason then rebooting automatically
Hi my dell dimension 5100 is turning on and off automatically for no reason. It powers completely off and then reboots back on automatically. I brought it to a computer repair place and the guy took it apart then put it back together and said hopefully that works. well it didn't. I spent two hours on the phone with a tech from dell and he came to the conclusion that it is a motherboard problem. I guess my question is does this sound reasonable and if so is it worth it for a computer that is now 3 years old.
  • MosschopsUK Apr 02, 2009
    System turning completely off for no reason then rebooting automatically - even in SetUp!
    I've tried everything here - removed all components so just the MB is connected to board, still reboots when in SetUp (BIOS) - the furthest I can get the damn thing to go is to the Windows start-up screen, then reboots. Even tried different PSU and RAM. I'm at a loss - is the CPU or MB screwed?
  • 1,226 Answers
That kind of problem is very common to all computers. There are three possible causes. the power supply got shorted, The memory got dump and cannot resist to load the operating system. The system got conflict both the hardware's and software's.
1. try another functional power supply or test your power supply with appropriate tester.
2. REmove and clean the memory both the bank and the chips and test. if same problem occur then try another functional memory.
3. last; format and reinstall the hard drive to renew and refresh all setting and install all the drivers.
if these solution won't work that the time that the motherboard got shorted. however if in the first boot the system display it bios then that can be resolve.
tell me if ever what happen.
Posted on Oct 19, 2008
Dimensions 9100 added RAM now won't boot remove batery and will boot or reboot not from power off
Possibly a bad power supply. If you remove all the memory and it still won't power up unless you remove and re-insert CMOS battery that is a symptom of a defective power supply
Nov 10, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
My dell dimension 5100 keeps freezing up.
could be a number of reasons, does it have the internet? does it freeze just after booting or after a few mins/hours of usage? have you tried cleaning some of the stuff you dont use off the harddrive? have you tried running a system scan with an antivirus?
Sep 25, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 5100 won't start... Power button blinks yellow.
hi disconnect pc and try to charge ups without anything connected
Dec 04, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 shuts down then reboots automatically, This is one bugger of a problem. Had continual problem with unit shutting down no rhyme or reason, cant see BSOD message off too fast. Did change...
Try rebooting to Safe Mode. Right-click on My Computer and hit Properties. In the System Properties window, click on Advanced. Then click on Startup/Recovery Settings. Uncheck Automatic Restart. Then post the BSOD Stop Code here.
Nov 18, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 power up problem
I had same issue with dimension 5100 Desktop. I work at Circuit City as the Lead Technician. I found that swapping the power supply did fix the problem! When i initially tested the power supply with a standard power supply tester, the power supply appeared normal. But after swapping the PC works great. Thx for the good idea!
Sep 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
80 people viewed this question
Alun Cox
