Question about Amigo HD450 3 Wheel Scooter with 33AH Battery Cinnamon Model
Amigo smart shopper
How can i make the amigo smart shopper fasterit seems to be realy slow and would like to get around faster if posible
  • Dan Hudson May 11, 2010
    We need to set a level here. Scooters are requalted to go only so fast due to medicatre regulations. You need to change the settings in the controller to fix this, very risky without proper documentation.
Lose weight
Posted on Feb 28, 2018
Posted on Jul 13, 2010
How do you add a throttle control POT to an amigo value shopper? I see where it goes on the circuit board but need to know the value and the pin out. Thanks in advance.
older smart shoppers had a speed pot built onto the throttle assy. but the value shopper is programed into the motor controller user can't change
May 13, 2014 | Amigo Health & Beauty
I need a manual for the amigo smart shopper cart
You will need a serial number, should be at the bottom of the steering shaft or in the battery compartment, call amigo at 1-800- myamigo for help when you have it
Jan 12, 2014 | Amigo Smart Shopper Scooter
How much does a new amigo value shopper scooter cost
Grainger has them for $2630 new. There are used ones on ebay for $350
Sep 14, 2013 | Amigo Value Shopper Scooter
Controls won't respond
Does the battery indicator light up. If it does then remove the rubber seat cover to expose the seat safety switch then turn power on hold seat switch down and try the throttle if the cart moves then try to put 2 10 x 10 pieces of card board on top of the foam directly above the seat switch then put the rubber cover back on.If it doesn't then have the on off switch and batteries checked or contact amigo for the nearest service company in your area (1-800-my-amigo)
Apr 04, 2013 | Amigo Value Shopper Scooter
Have a amigo smart shopper scooter and "dead man" switch apparently not working correctly. When I depress thottle, scooter goes forward without any weight on seat?
need to know how old unit is smart shoppers now use seat switches that are normally open without weight and when seated normally closed, if you unplug the wires that come from the seat switch and the cart doesn't move then the seat switch is stuck and should be replaced. older units were normally closed without weight and normally open when seated in this case check to see if the wires have come unplugged and reconnect them then recheck if cart won't run when seated replace seat switch.
Feb 01, 2013 | Amigo Health & Beauty
I want to reprogram an Amigo Value Shopper to have a faster top speed
Sorry but you would need a programmer to attach to the controller I am a service tech and use it to program the controllers
Nov 03, 2012 | Amigo Health & Beauty
I snapped the cable on my amigo value shopper what do i do
if it's the wire that drags on the ground it's a static ground, you can order a replacement from amigo or make one from a piece of stranded copper wire (14 gauge)
strip 3 inches of insulation then wrap once around axle and twist together cover twisted portion with electrical tape to hold together make long enough to allow end to drag on ground
strip 1 inch of insulation to allow wire to contact the ground and that's it
it it's the gray flat cable or the motor wire it will need to be replaced
Sep 09, 2012 | Amigo Value Shopper Scooter
Where are settings on amigo smart shopper
In the motor controller and depending on the age may or may not be adjustable without a programmer
Jun 05, 2012 | Amigo Health & Beauty
Instruction manual for the fisher-price smart shopper marketplace
If you can get me a product number, I think I can help you. Send me an email at
Jun 09, 2009 | Toys
Amigo HD450 3 Wheel Scooter with 33AH Battery Cinnamon Model Logo
926 people viewed this question
Top Amigo Health & Beauty Experts
Tom Chichester
K McMurdo
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
