Question about Akai PT4298HD Rear Projection Television
Lost Remote Old Remote had a game button for my play station system. I need to program a new remote. will you suggest a remote for a Symphonic 20inch flat screen, with a game button.
    Genius:
  • 2,920 Answers
Why not contact symphonic and have them send you another remote? it should be just like the original
Posted on Oct 19, 2008
How do i get to the input of the symphonic tv model:sc3813
You should be able to access the A/V input by cycling through all available channels (using the Channel Up/Down buttons). You may need the A/V device to be powered on. However, if you programmed the Channel list to skip Aux, you may need to add that back into the list. You need the Menu function on the remote. Use the Up/Down arrows to navigate to Channel Set Up. Then press the F.Fwd (right arrow) to enter the sub-menu. Then select the Add/Delete Channel option.
Another way to access the A/V input is accessed by pressing the Game button on the original remote. (This also adjusts the screen lighting.) The game button is the middle button on the last row of buttons on the remote. If you do not have the original remote, you need one that matches that function. Here is one that is guaranteed to work: http://remotes.com/store/symphonic/sc3813.html . This one may also work: http://www.emtcompany.com/symphonic-sc3813-remote/rc64.html .
The Symphonic SC3813 was manufactured by Funai. The manual is available from Funai service support: http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/ . The direct link to the manual is http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/SC3813.pdf .
I hope this helps.
Mar 01, 2015 | Symphonic SC3813 13 in. TV/VCR Combo
How to turn a symphonic tv into game
symphonic is well known for this-no buttons on unit for key features and a universal is not going to help either, suggest you go in search of the original remote and hang onto it.....
Aug 28, 2012 | Televison & Video
How to get universal remote to turn the tv to game mode
I don't know if this can be done with a universal remote, but if you can let me know which brand and model of universal remote you are using, I will check if it is possible. If your universal remote has an "AV", "SOURCE" or "INPUT" button, try these but make sure the game system is switched on so you are able to see if/when you have changed to the correct mode.
If you don't have the original Symphonic remote, you should be able to switch the TV to game mode using the buttons on the front of the TV as follows:
1. Switch the game system on
2. Press the "MENU" button on the front of the TV
3. Highlight "PICTURE" using the CHANNEL UP/DOWN buttons
4. Press the VOLUME UP button once to enter the PICTURE menu
5. Highlight "GAME MODE" using the CHANNEL UP/DOWN buttons
6. Use the VOLUME UP/DOWN buttons to set "GAME MODE" to "ON"
7. Press "MENU" to exit the menu and play games.
The menu should automatically close anyway if you don't press any buttons for about 15 seconds.
When you have finished playing your game, repeat the above steps to set "GAME MODE" back to "OFF" and return to watching TV.
Hope this helps. Please post back for further assistance if needed.
Regards,
BElectric.
Dec 23, 2010 | Symphonic ST419E TV
Have a symphonic tv model number wf24t5 and lost the remote... is there any way without the remote to turn it onto game mode
Yes go to menu with the buttons on your TV and go to CATV sometime u can press your channel button until your channels run out and if u keep pressing the channel button it will go into game mode or in other words switch to the RCA jacks in front of your TV
Aug 13, 2010 | Symphonic ST419E TV
What is the code for a symphonic tv and a rca remote. I also need insructions on how to program the remote that works with my tv. I lost the instructions
These are the steps on how to program your RCA Universal Remote Control to your Symphonic TV.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV button. When the TV button flashes proceed to the next step.
  3. Enter the three digit code. In your case, the code for the Symphonic TV are 064 or 076.
  4. Release CODE SEARCH.
  5. With the TV on, press another button, for example CHANNEL UP. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-5 using the other code number.
Jun 12, 2010 | RCA Universal Remote Control
Tv needs video to play games but lost remote
Buy a universal remote, the codes for each individual TV are in the manual, and program that remote to work with your current television.
Jan 26, 2010 | Symphonic ST420FF 20" TV
Unable to program my Time Warner Cable remote to Symphonic TV
the instructions are on the back of the remote. if lost. you have to:
1) Turn tv on ( i would suggest turning it off then on)
2) Press the Device you want to sync (tv)
3) Press and hold the setup button it will blink once...let it blink twice before you go to the next step.
4) press 9-9-1
5) press the power key on the remote
6) press the channel up (CH +) button repeatedly until the device (tv) turns off.
7) when it cuts off immedieately press the setup button.
Mar 14, 2009 | Symphonic WF20D4 TV
I own a symphonic 27" television
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote. The thing with the menu and buttons on the front of the TV doesn't actually change the TV to true game mode. I don't know what it acutally does, but it isn't really in game mode. When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Make sure you look at it before you buy it and make sure it has a button that specifically says "input" on it. I know that some of the universal remotes don't have an input select button or one that doesn't work. As long as you get a Philips-Magnavox that has that button, you should be ok. Much better solution that paying 30 bucks for a new remote specifically for the TV. Hope this helps.
Mar 04, 2008 | Symphonic ST419E TV
I cant get aux on my symphonic tv to play
Try Channel down from 2 or up from 99.......T.
Jan 22, 2008 | Televison & Video
My tv remote stopped working
Try using words to form sentences next time.
Don't lose the remote; tie a scarf on it with a key-finder in it and a pesto or frosting saran pack in the battery compartment if you have to.  You do.
Because now, you get to go buy a universal remote and program it, or use a universal remote program on a PalmPilot, cellphone, or IrDA-equipped PC.
Alternately, you could take advantage of any automatic input priorities the TV set has which are compatible with your game cabling.
Dec 26, 2007 | Symphonic WF104
Akai PT4298HD Rear Projection Television Logo
52 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
