Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony 2006 40s2010
Dvd pic quality is VERY poor. The only connection I have not used is the hdmi. The quality is about 480i. I thought that this tv was between 720 and 1080i in resolution. Is there a switch that I am missing? How do I get better quality?????
  • 320 Answers
It very much depends on:
the model of DVD player you have and whether it is a standard or blu-ray player
the settings on the player
the type of connection (component and HDMI will yield a better picture)
Posted on Oct 19, 2008
What is the screen resolution to the sharp 32C540 ?
480i is the highest resolution of your tv. The tv has composite, s-video and component inputs in the back. The manual states that with component connections are dvd compatible allowing you to enjoy the highest quality image playback than using s-video. Dvd's resolution are 480i or 480p. I'm guessing it's more 480i than 480p since the tv is a crt tube tv and does not have any of the digital inputs for higher resolutions.
Jul 06, 2011 | Sharp 32C-540 32" TV
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
I have sony bdp s300 tonight it began intermittent loss of HDMI signal. It comes and goes. Not the cable, just upgraded to the most recent software. No damage to the HDMI port. This one has me beat.
What brand of tv do you have?? Also what resolution does it display? 1080i, 720p,480i or 420p?some DVD's only use certain ones. U gotta make sure your TV can display the resolution from the DVD.
Jun 28, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Ps3 hdmi cable with adapterto tv's rca's
Just use the regular AV cords. They are 480i using an HDMI to this and that isn't going to improve picture quality.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Oct 05, 2008 | Sony DAV-HDX500 System
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Component Cable
Are you just using the yellow cable at this point, because the quality would in fact be awful? Using the green, red & blue cables (component cables) would not improve quality much, seeing as the yellow video cable has a resolution of 480i and component cables are set at 480p. Your TV (if it is in fact high definition) would either run at 720p or 1080p depending on what the manual says and what the native resolution is. I would say try and buy and upconvert DVD player and make sure to get an HDMI cable to go from the DVD player to the HDTV (some DVD players come with this cable, but you'll have to look around for them, otherwise look on or something for some cheap ones). HDMI connection and the upconvert DVD player will improve picture quality significantly.
Apr 23, 2008 | Televison & Video
RCA DRC8052N DVD recorder
Try the input button on the DVD remote. You may have to move it to AV1 to get a picture??? Just a suggestion.
Nov 18, 2007 | RCA DRC8052N DVD Recorder
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
123 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
