Question about Hoover F7458-900 Upright Vacuum
Buzzing noise when machine is turned on
We were using the cleaner, emptied the waste water, then tried to turn it back on. There is a buzzing noise (sounds like hair clippers) but no function of the brushes or sprayer. All of the tanks are seated properly, and we cleaned the brushes. It does this in all three brush positions. At one point, we moved the machine from one room to another, and it started up correctly, but when we turned it off to move a chair, it quit working again. It was only on for a few minutes at that point, and the motor was not especially hot.
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
Burned up motor. Take it to your local vac shop for a quote on repair or replacement.
Posted on Jun 12, 2017
  • 126 Answers
SOURCE: Brush won't spin when position of handle changes
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Posted on Jan 27, 2008
keemo68
  • 1263 Answers
SOURCE: Brushes won't turn on a Hoover F7426-900
there should be a rubber belt that drives the brushes on either side. hope this helps. please rate this.........thanks
Posted on Aug 30, 2008
SOURCE: rug and floor nozzle brush not moving
What I had to do was take apart the vacuum head...which is very confusing, and the manual doesn't tell you how...the "secret" is to use a flat screwdriver to pop out the little wheels...there are two other screws "hidden" beneath them. Be careful as this exposes all the electrical parts as well - make sure you're unplugged! : )
Posted on Jan 04, 2009
landsend
  • 1066 Answers
SOURCE: hoover windtunnel vacuum roller brush doesn't
does the motor turn?  if it does replace the belt.
Posted on Apr 04, 2009
CorvetteKing
  • 108 Answers
SOURCE: Reassembly of brush roll bearing/washers on Hoover Runabout
It will make no difference which direction those washers are installed, just that they are installed.
Posted on Jun 05, 2009
My Sebo X4 does not switch on, when powered up two red lights flash momentarily. There was a buzzing from the black box underneath but that has now stopped. I changed the bag yesterday as it said it w
Your red lights flashing momentarily is normal start-up. The fact that your servo motor is operating tells you that you are getting power. If the vacuum motor does not turn on, you likely have a problem with the motor itself or the power supply board that feeds power to the motor. These items should be covered under warranty. However, if your vacuum is outside the manufacturers warranty, you can replace either of these parts fairly easily with only a phillips head screwdriver.I have included a link to the parts list for this machine. We do stock both parts. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Sep 24, 2014 | Sebo X4 Extra Bagged Upright Vacuum
My Dyson D17 Animal vac makes a buzzing noise when the belt turns. I took the belt off and turned the small metal gear that turns the belt. That is what is making the slight noise. My wife vacuumed the...
Try not to **** up any more water. Don't use until you can dry it out well. Hopefully you live in a warm climate so that will happen sooner than later.
Sep 23, 2013 | Vacuums
Bissell promax plus pump not working, only buzzes
Sorry to hear about the buzzing sound from the pump of your machine.
Now would be a great time to invest in a new machine that's provided with a new warranty. We offer free shipping on orders $30 or more.
Here's a quick link to our current deep cleaning machines.
http://www.bissell.com/deep-cleaner/?cid=ccsocial
Apr 04, 2013 | Vacuums
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    We have just opened a De Longhi Icona coffee maker. We followed the instructions to start it, but when we press the coffee button (after the OK light comes on), it makes a loud buzzing noise and no water...
    may be you may forgot to fill it up with water...... otherwise i request you to please read the manual book which was given along with machine so that you may get the appropriate solution
    Oct 22, 2010 | DeLonghi Vacuums
    My bissell cleaner bottom brushes are not turning and the big tank of water is not working only the small stain tank is working. it is still sucking up the water
    Check the brush drive belt has not broken by inspecting from underneath. See the manual pages 21 & 22 for removal instructions. Download a copy from the following link
    http://uk.bissell.com/images/UserGuides/9500E.pdf
    This may be caused because the pump belt has stretched or broken or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
    Main causes for no spray.
    Bladder may be empty.
    SmartMix Bottle may be empty.
    The Filter may be clogged.
    Tanks may not be seated properly.
    Pump may have lost prime.
    The Pump Belt may be broken.
    2 front jets are blocked. This is a common problem. When the machine is standing for a while the detergent turns to a gel causing the blockage Lay the Bissell on its side then where the water comes out of the jets at the bottom of the machine unblock them using a pin to poke through the hole in the centre.
    Try running hot water through the system with no detergent to empty out all the residual detergent. Keep running hot water through the system by pressing the button you press for it to spray the water do this for about 5 mins and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage. Do this once a month to ensure that the pipes and jets are kept clean and free of any detergent gel build up.
    Nov 13, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Not Sucking the dirty water
    It seems that when you emptied the recovery tank it has not been placed back proper.
    please make sure it is sealed else you will loose suction
    Jul 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
    Bissell won't turn on
    the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
    Feb 01, 2009 | Bissell 6594 PowerForce Bagless Upright...
    Hoover steam vac dual v makes humming noise and nothing else.
    Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
    Oct 09, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
    Hoover F7458-900 Upright Vacuum Logo
    64 people viewed this question
    Top Hoover Vacuums Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
