Question about Hobart D300 Stand Mixer
Bought Hobart D300-T at auction
I bought a Hobart D300-T at an auction and have no clue of it's history. The handle won't dop the bowl. I can here a spring sound when I try to move the handle.
Also,... it won't start. I took off the top cover and not sure what to do or look for. Is there a diagram of the workings?
Thanks
Try some carb cleaner behind the bowl arm. Your arm might be frozen on the slides or the ecentric on the handle is broken. But chances are it needs more work as well. If you want to sell it contact us at machinerysurplus at yahoo.com
Posted on Dec 17, 2008
I have another for sale - working 1500,00 cdn
Posted on Oct 23, 2008
What kind of oil i can used for hobart d300
Transmission uses #0 weight grease, best to get direct from Hobart (their grease is the correct weight and approved by U.S. FDA & USDA as safe for use in food equipment) but if you insist on not doing so, at least obtain an Extreme Pressure #0 grease and don't overpack the transmission, I believe it should have 35 oz. if memory serves right.
Uses a heavier grease for the planetary gear, use #2 weight. Don't need much, just a light coat on the planetary gear.
Bowl lift rails use medium weight oil, again use food grade oil supplied by Hobart.
Aug 02, 2010 | Hobart D300 Stand Mixer
Oil leak
Possibly, but to be safe replace the seal
Aug 21, 2009 | Hobart D300 Stand Mixer
Hobart D300 Mixer, Will not shift from 2nd to 1st gear without coming to full stop, Ideas as to source of problem? It also seems to be making increased noise.
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Jul 23, 2009 | Hobart D300 Stand Mixer
D300 Floor Mixer faulty bowl guard switch
If you remove the bowl guard you will see a magnet that attaches on iy in a white housing.The scews come loose and prevent it from closing the switch.Also the switch which comes out of the top pedestal can be adjusted.Let me know.
Mar 29, 2009 | Hobart D300 Stand Mixer
Bowl won't stay up
Hi. Goto www.hobartservice.com and register for free.
Search for your mixer model in the Discontinued Products area.
Download file# F6731.pdf On page 4 find the drawing labled PL 2523 If your reassembly geometry doesn't match that of the drawing, you must correct it. If this solution has assisted you please rate it. Good luck!
ricardok45
Mar 22, 2009 | Hobart A200 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
New bowl & hook hobart d300
There is a website called onesharpstore.com, It carries parts for the hobart 30 quart mixer. I specifically saw the bowl and hook attachments as well as others like beaters and a cheese and vegetable grater. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
Feb 25, 2009 | Hobart D300 Stand Mixer
Type of lubricant for bowl lift
Go to an auto parts place and buy some Lubriplate grease and use this on the assembly.
Aug 02, 2008 | Hobart A200 Stand Mixer
Age of a-200
There is a two letter code that translates to the month and year. You would need to call Hobart to translate. 1-937-332-3000
There are hints to the age, first two digit of the S/N is the factory. "11" are the older ones, spec vs ml on plate, type of power switch, bowl gaurd....
May 16, 2008 | Hobart A200 Stand Mixer
Hobart D300 Stand Mixer Logo
152 people viewed this question
Top Hobart Food Mixers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
