Question about Sharper Image SI655SIL Portable DVD Player
Trouble S.I. S1655
Mine keeps turning off on it's own or won't even turn on, goes into standby right away. if it does go on it won't change channels.
Tv won't power up straight away
when lcd tv`s fail to power up, but stay on standby. It is usually because of bad capacitors on the power board. My 22" lcd monitor did the same. It would not come off of standby. It starts with them being slow to turn on. "Sound familiar"? I fixed mine by changing the bad caps. There were two of them.
Jan 31, 2013 | Wharfedale LP160DTRHDMI
My 50in won't turn on
might have to change the bulb in the tv, should be in the back right corner should tell u something like a warning lable so u can find it,u will need a screw driver.
May 28, 2012 | LG 50PK250 50 HDTVReady Plasma TV
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
My 40' vivo tv has turned off and won't turn back on but the red stand by light is on??
If the standby light is on and it does not respond, it is most likely to be a problem with the power supply . First try this, unplug and leave the set like that for a few hours. Then plug it back in to see if the tv attempts to turn on when you try to power it up. See if you hear a "click" even if it goes back to standby. Let me know what you found so that I can help you test the power supply board to confirm, if necessary.
Aug 18, 2011 | Televison & Video
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
MODEL DLT37C3 KEEPS TURNING ITSELF TO STANDBY WHEN
Mine did this to. Opened up the back cover, the power circuit board is clearly visible, on it is a HUGE electrolytical capacitor 26mm in height x 35mm in diameter 150uF 450V. Changing this for a new was the cure for me. Might work for you as well! Please be careful, the capacitor can hold a high voltage even after power is off and cable removed, make sure to remove the powercord! If unsure ask someone that can solder to do it.
You will need a soldering iron (quite powerful) and some solder to change it.
Feb 28, 2010 | Daewoo Televison & Video
My wii will not power off the little light goes from green (when turned on) to orangekind of color.....this did not happen before until now that i set up my wireless internet to it
Your Wii is set to be on 24 connect. When you turn it off it goes into a stand by mode that allows it to get data for the weather, news, and shop channel. As well as get emails in. Its fine like it is. But if you want it to turn off, you'll have to go into the options and disable the Wii 24 Connect.
Jul 12, 2009 | Nintendo Wii Console
When i turn the tv on it goes to standby right away
If not under warranty, here's what you need to replace inside your TV. Power supply board BA71F0F01042.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Right now, only Discount-Merchant has one in stock. Here's the link:
Discount-Merchant.com - Projection LCD / DLP TV Lamps - Plasma ...
I know it would be cheaper to fix the TV, than replace it.
If you end up throwing the old board in the trash, I would like to keep it if possible. Here's my e-mail, dsacco86@hotmail.com
Apr 24, 2009 | Emerson LC320EM8 32 in. LCD TV
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Sharper Image SI655SIL Portable DVD Player Logo
Top Sharper Image Televison & Video Experts
Demonic-2011
Demonic-2011
Keith Peterson
Keith Peterson
Are you a Sharper Image Televison and Video Expert? Answer questions, earn points and help others
