Question about Ovens
Thermodor Convection Oven
I have a Thermador Convection oven Model CT130. The oven fan which should cut off after the oven cools, down now runs continually. I suspect the problem is with the thermocouple. However, the material that came with the oven does not cover technical informatio like an exploded assembly/parts view. Can anyone help?
Gayle Wylie
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Posted on Apr 05, 2008
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a Thermador electric
Welcome to FixYa.
You have not mentioned if the oven has displayed any error code so I will take that for what it is...there was none shown.
With that, I`d start by looking for an overtemp cut-out tripped. Did this problem start following a self clean cycle ?
Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
If you feel capable of repairing this yourself I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can.
macmarkus :)
Posted on Aug 05, 2010
cmt4wa
SOURCE: set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Posted on May 31, 2012
Our Thermador oven starts to beep when you shut it off and the way we are getting it to stop beeping is to set up a fan in front of the open oven to get it to cool. This stops the beeping after 10 m
Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
Oct 14, 2014 | Thermador C301U Electric Single Oven
NOISE WHEN OVEN RUNNING
could be the cooling fan or the convection fan motor. Your question is too vague.
Dec 02, 2013 | Thermador SC272T Electric Double Oven
Looking discontinued thermador parts
Refer your problem to an appliance parts distributor
Jun 08, 2013 | Ovens
What does E 2 on a thermador convection thermal double oven mean
depending on the model, could be run away cook/clean temps.
Oct 15, 2012 | Thermador Ovens
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Jan 30, 2008 | Thermador SC302T Electric Double Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
Ovens Logo
62 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
