Hi. There is two ways to determine compression. A dry test and a wet test.
Check the compression dry and write it down. Squirt some oil into the cylinders and check it again. If the compression doesn't come up the problem is in the upper end, If the compression shoots up higher, the problem is in the bottom. ie:rings. (depending on the year make model
2 stroke 4stroke etc)Good Luck Vern
SOURCE: my dr 250 1984 has low compression
your carb got stuck and it sounds like your rings are burnt out like u were running to high of an octane or something in your gas
SOURCE: just rebuilt the top end on my 1999 kx 250 and won...
Cylinder bolts @ 25 ft/lbs (34Nm)
Cylinder head nuts @ 18ft/lbs (25Nm)
Check these nuts again after first warm up and again after first two rides to let gaskets bed in and seal. Cheers.
SOURCE: I have a Kawasaki KX
does it have spark and are the rings in right aliment and is the gas on i have made that mistake
