Nor do my brake lights, but my right turn signal works, fuses fine, everything seems to be grounded, can't figure it out, can someone help me?
SOURCE: 2005 GMC Pickup speedometer does not go to zero
There was not a recall, but there was a class action settlement where GM agreed to extend the warranty on certain vehicles for this problem. Check www.gmspeedometerrecall.com to see if you qualify.
SOURCE: tail lights work on both sides. turn signal and
check fuse to driver side turn signal lamp.check brake light bulb or replace bulb on driver side.also replace the front driver side turn signal bulb that is flashing fast.
SOURCE: Replace starter on 1992 GMC Sierra pickup truck
First thing unhook positive battery cable, unhook main cable on starter selanoid and small wire on selanoid (there may be 2 small wires) There may be a bracket on front of starter that has to be removed, and then the 2 main bolts that hold it to engine block and it should come out.
SOURCE: 1990 GMC Sierra 1500 pickup. Windshield wipers, Cruise Control
May want to look at replacing the wiper circuit board.It is located on the firewall adjacent to the wiper motor and has a some what square black cover with 3 torx screws and wireing harness pluged into the side.We had a truck that every time you washed it the wipers would stay on until it dryed out.You can try removing it and spaying it down with contact cleaner just watch the brease on the two contact tips.Well hope this helps.
SOURCE: low oil when engine warms up gmc sierra 1995
30-40 psi of oil pressure is fine for many vehicles including your GMC. I am assuming that the truck has more than 100,000 miles on it and still has the original engine in it. By rule of thumb you only need 10 psi per 1000 rpms in a typical street driven engine to give adequate oil pressure to keep the bearings from oil starvation. The oil pressure is typically higher when initial start up occurs because it is more viscous due to the temperature of the oil as the engines oil warms up the visconsity thins out and the oil flows more smoothly. The drop in oil pressure is a normal occurance. Above 45 is more than required for a daily driven street engine. I believe that the specs on that engine only list 30- 45 psi.
when I hit a bump my turn signals don't work properly.
