Hp photosmart 2575 won't feed paper and always says there is a paperjam.
  • 3 more comments
  • soltdog Oct 30, 2008
    paper wont feed. feed roller turns but doesnt grip paper and it says paper jam
  • Anonymous Nov 06, 2008
    Keeps getting paper jam error.
  • manojmoorjan Jan 20, 2009
    I have the same problem, and ended up having to buy another one.
  • emazzei221 Jan 29, 2009
    when i try to print the paper pulls to the right side and jams. I went to epson help page and what they told me but that did not work.
  • Anonymous Mar 25, 2009
    I have the same problem with the 2575 and my previous HP printer. Think I going to change printer company next purchase
  • 1,218 Answers
Does not want to feed paper at times
Erratic print feed is usually due to Quality of paper or the cleanliness of the rollers which pull the paper through the machine. You User/instruction manual has advice Paper quality and on how to clean the rollers. Make sure the machine is switched off before you attempt any internal cleaning
Feb 19, 2010 | HP Photosmart 2575 All-In-One InkJet...
My HP 2575 Photosmart all-in- one will not feed paper. Message says out of paper when it is full of paper
there is paper feed sensor inside the printer. make sure it is there and not broken off. the sensor is in the back center of the paper tray, and is spring loaded. if you can't find it, shake the printer with the paper tray facing down to see if a black piece of plastic falls out. the printer will also have this error when the printer cannot pick up the paper. clean the rubber roller with "rubber renew". you can use rubbing alcohol but rubber renew is recommended. the roller is often full of dust and fine paper debris.
Nov 15, 2009 | HP Photosmart 2575 All-In-One InkJet...
I have an HP Photosmart 2575 All in One printer. It is not feeding the paper for some reason and it tells me that it is out of paper.
reset the printer by unplugging the power cord of the printer while its on and putting it back in after 2 minutes. if this wont solve the problem then try
adjusting the paper settings. and if it still wont work clean the rollers. this would be the last step. if not solve the printer is of no good
Oct 31, 2009 | HP Photosmart 2575 All-In-One InkJet...
Paper will not feed
It is a problem with printer paper sensor pls clean the printer paper sensor. if problem does not solve then you can checked it from service center.
Oct 20, 2009 | HP Photosmart 2575 All-In-One InkJet...
Paper won't feed correctly
Try to place the paper properly keeping tray in place. Check for any paper jam.
Jun 09, 2009 | HP Photosmart 2575 All-In-One InkJet...
Paper feed will not work
Remove the access door in the rear and clean the black rubber rollers with alcohol.
Feb 21, 2009 | HP Photosmart 2575 All-In-One InkJet...
Problems with the paper feed.
I had this same problem with my HP 2575 printer. I complained very strongly to HP and they sent me (free of any charges) an HP Paper Cleaning Kit. Took about 20 minutes to clean and rough up a rubber feeding roll in the printer. VOILA-- printer has been feeding perfectly for over a year. A friend of mine with the same printer,had the same problem. He used it and now has no problem. You will have to get after HP and have them send you the Kit. Hope this helps you out. SANS
Nov 20, 2008 | HP Photosmart C5280 Printer
Paper jamming
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 13, 2008 | HP Photosmart 2575 All-In-One InkJet...
611 people viewed this question
jasbo
jasbo
