Question about Miele Washing Machines
Miele w4800 touchtronic washer is frozen. No lights and wont start. is there a way to reset?
5 Suggested Answers
SOURCE: How to fix a Miele
check drain pump is not blocked if so clean out
Posted on Mar 15, 2008
  • 3 Answers
SOURCE: miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Posted on Aug 11, 2009
  • 177 Answers
SOURCE: my miele touchtronic w 3039
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Posted on Mar 02, 2010
  • 128 Answers
SOURCE: hey there, i got a miele w4800 front load washer
You have water in the bottom pan of the machine. grab it at the back and tilt it forward. the water will run out and it will start working again, but you will probably need a concertina hose. This is the hose that connects the detergent compartment to the wash drum.
Posted on Feb 24, 2011
My Miele washer W4800 is rinsing out gravel and sediment . I have a lint trap on the drain and its a fairly large amount.
What does this have to do with the washer, not sure what you are asking here, please elaborate on the problem you perceive to have??
May 19, 2017 | Miele Washing Machines
Does anyone have the parts schematic for Miele Touchtronic W4800 drum assembly?
Attached is a IPB for the drain section - are you speaking of Item number 1? This was an issue at one time with the intake side - a piece of felt glued to the drum stopped the chaffing. 5471732e-e156-4138-ab0a-dca218299e0f.jpg
Aug 16, 2014 | Miele Washing Machines
Need w4800 model Miele seal
Click on : Washing machine spares
Jan 23, 2013 | Miele W 4800 Front Load Washer
Hey there, i got a miele w4800 front load washer that stopped working all of the sudden. The buzzer is going crazy and the drain and intake fault lights are flashing. Any ideas of how i could fix this...
Feb 15, 2011 | Miele W 4800 Front Load Washer
Drsining washer manually
open the little door at the bottom fron and twist open the lint filter clean out
Jul 12, 2008 | Miele Touchtronic W1113 Washing Machine
Washing Machines Logo
138 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
