Question about SanDisk Sansa e100 MP3 Player
Bleeding screen the other day my sansa's screen broke and started to bleed inc so now i cant see or decide what i am listening to is there any way to fix it or should i just get a new one.
  • 513 Answers
You can't "fix" a broken LCD screen. Just replace it or the device. The bleeding means it's actualy broken, not scratched or anything. It won't be easy to replace the screen itself, mainly because it's not that easy to find a replacement screen - you can look in ebay for a dead one with a working screen, but I don't know of any manufacturer that sells these parts alone. Then it's the matter of opening it up without damaging it, and connecting the right X to the right Y. Tiny screws, and very small electronic parts. Bottom line, you can do it for a hobby, but if you just want a working mp3, go buy one. Good luck
Posted on Jun 26, 2006
Its much cheaper to buy a new screen. You can go here to buy one: www.aerozbooks.com
Posted on Sep 06, 2007
Put a bandaid on it over night if this does work wash it with dettol and apply SAVLON. hope it works
Posted on Jul 21, 2007
Put in into a super industrial case so that when you drop it it wont break
Posted on Apr 13, 2007
SOURCE:
Hello i broke a fuel line off the tank I put it back on and now primed and bleed from the fuel filter but still wont start. its a hino truck 91 tipper truck
start at the filter and bleed the air , next is the bleed screws at the pump (could be one or two depending on the make ) if it doesn't start then loosen off all the injector lines at the injectors and crank the engine until you see fuel dripping from the nuts ( that is bleeding the air from the injector line s)
have someone tighten the nuts while cranking and it will then fire up as the nuts get tightened
Mar 24, 2017 | Cars & Trucks
How to bleed the brakes after replacing the front caliper
Your master cylinder seals could be by- passing internally or it is not being bled right.
Try one of those self bleeder kits.Have a clear hose installed on the bleed nipple tightly and have it immersed in brake fluid in a jar -loosen nipple and slowly press the pedal till you see no bubbles in the hose then tighten nipple.ps- start from the furtherest wheel.
May 18, 2012 | 2002 Oldsmobile Alero
I cant get the air to bleed out of my brakes on a 1997 dodge dakota i put on a new master cylender and have been bleeding them for 2 days they seem to bleed normal when truck is not running pump up and...
You need a helper, to slowly press the brake pedal down, as you open bleeder valve,then close before your helper gets near the floor.
Repeat until all air is out of each wheel position.
RR,LR,RF then LF. Always start from the farthest wheel and have motor running
Never pump brakes. That does nothing at all.
Nov 03, 2010 | 1997 Dodge Dakota
My clutch went out and i had a mechanic friend replace the part...its the part under the engine not the actual clutch but he cant get pressure back in the clutch and cant figure out if bleeding the system...
Bleeding the system is as follows. It also helps if you have a length of clear plastic tubing that fits snugly over the tip of the bleed nipple, which makes it easier to see if there are any air bubbles still coming out.
1. Start with the Master Cylinder full of fluid. (Don't forget to check after a few bleeds that it stays above ¼ full so that you don't introduce more air into the line).
2. Have an assistant pump the clutch pedal 2 or 3 times, then hold down, keeping weight on the pedal as fluid is released.
3. Loosen bleed nipple to release any air & fluid.
4. Tighten nipple. Assistant then lets clutch pedal return. It may be necessary to manually pull back pedal if it does not return by itself.
5. Wait a few seconds then repeat the sequence from #2.
Bleeding is complete when no more air bubbles are visible in the fluid released from the bleed nipple. If clutch is still spongy you may have to repeat the bleeding after a few days driving.
Oct 27, 2010 | 1988 Toyota Pickup
Brake line broke, replaced it, now I can't get fluid to the bleeders. I hear air but cannot get passed that. Now I have no brakes at all.!!
did you bleed the system good from air pockets...sometimes you have to remove the brake master cyclinder and bench bleed it to get all the air out...but your problem is to much air in system...start with bench bleeding the master cyclinder first.
Aug 15, 2010 | 1997 Nissan Pickup
Engine runs hot.have ereplaced waterpump which was bad& replaced tstat.how doI bleed cooling system.
1. Fill the coolant in the coolant expansion tank
2. Ensure that no coolant leaks from the radiator and pump
3. Identify the coolant bleed screw, this screw is just beside the thermostat
4. Start the engine and loosen the coolant bleed screw. Now coolant comes out with air bubbles. allow the coolant to flow until coolant comes without air bubbles.
5. Tighten the coolant bleed screw.
Sep 22, 2009 | Sierra Online, Inc. Planes, Trains, and...
How do i bleed brakes for 1992 e mercedez what are the steps it still doesnt get stiff i cant find where to bleed in the front i just replaced the master cylinder
hello,good day,since you replaced your master cylinder,try first to bleed your master,then if you bleed the system,remove your wheel for easy access on bleeding screw,right rear first to open the left rear and front,ty
May 17, 2009 | 1992 Mercedes-Benz E-Class
My sansa e260 is broke.. HELP ME PLEASE!!!!
you have 2 things to do : 1- if you have the warranty you could exchane it. 2- Go to an lectronic store and buy the screen seperately, take the first one off than put the other one.
Mar 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa screen
break something under warantee and send it in
Apr 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e100 MP3 Player Logo
1,106 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
