Question about Beko 324250WN 28" TV
LOOSE SCART (NOT THE SCART LEAD) BUT THE PART OF THE TV THAT YOU PLUG THE SCART LEAD INTO IS LOOSE AND WONT SUPPORT THE WEIGHT OF THE LEAD. AM I ABLE TO TIGHTEN IT? AS EVERY FEW MINITES I LOOSE THE PICTURE AND HAVE TO GET UP AND PUSH THE SCART BACK IN. PLEASE CAN YOU HELP? PINKY1998 ANITA
  • ANITA PITTS Jun 24, 2006
    MANY MANY THANKS. YOUVE BEEN A GREAT HELP.
    PINKY1998
    President:
  • 3,130 Answers
Theres no way to tighten this as its gonna need to be resoldered and you must have experience working on tv sets due to the hI voltage issues here. If you take it to your repairman now hopefully its not to late and can easyley be repaired. Good Luck
Posted on Jun 23, 2006
What weight is this TV? I'm wanting to get a TV wall bracket so I can put this on to the wall. As this is an old TV and has no Freeview is there a way of connecting/getting Freeview to work
Yes there is a way buy a freeview box with a legacy scart plug connect to TV with a scart lead and use the freeview box remote to change the channel on the decoder and have the av input for the decoder on the TV and use the TV as a monitor only
as to the weight and how to mount the TV type and model would be helpful
Jan 22, 2017 | Televison & Video
What lead do I need to connect a DVD to Tv with no scart socket Technika 40E21B-FHD
the TV has component input so if you get an AV lead will come with 1 white leade and 1 yellow lead at each end, plug them diectly into TV and then at other end of cable get an AV to scart adaptor for your DVD had to same for my daughters TV and dvd as had no scart
Dec 12, 2014 | Televison & Video
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
Connect a dvd player to my tv
on the back of your dvd player and tv - you should have what's called scart sockets. Most dvd players come with a scart lead - you just have to plug one end of the lead into the back of your dvd player labelled tv, then the other end into your tv.
Nov 25, 2011 | Televison & Video
How do I connect my dvd player with a virgin box do I need 2 scarts in my tv?
Your virgin box should have two scart sockets,if you only have one scart socket on the tv then...Put a scart lead in the one marked tv on the box and plug it into the tv,then from av1 on your dvd take a scart and plug into the other socket on the box.If you cannot get the dvd to play when the box is on then switch the box off.
Oct 27, 2009 | Televison & Video
I have a bush vcr 902 and would like to know how
Take the main aerial and plug it into the vcr,then take a male to female fly lead from the other connection on the vcr and plug it into the tv,then take a scart lead from av1 on the vcr and plug into the scart socket on the tv
Oct 02, 2009 | Televison & Video
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
Hii i cannot connect my tv to the dvd player , can u tell me how can i fix this problem
I wrote this down to connect at Digital Freeview box to TV and to Video. It works for me on a portable TV and I am a grannie so if I can do it ............ I did buy one of those scart boxes which allows 4 scart leads just like an electric plug multi socket, very cheap price. Hope this helps and Happy New Year.
Take the scart connector box lead to the digi box.
The scart from the TV and the scart from the Video both go to scart box.
TV aerial itself not plugged in or used.
Bottom video aerial to right digi hole
Another aerial lead (not aerial) from TV hole to left digi hole
Jan 02, 2009 | Insignia LCDTV26 26 in. Television
Xbox/TV
Try using a scart switch, therefore you only have to use a basic scart lead from the TV to the switch. then plug your xbox scart into the switch and it should work
Nov 03, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Beko 324250WN 28" TV Logo
153 people viewed this question
Top Beko Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
