Question about Proscan PS36800HR 36" TV
TV won't stay on, cycles off and on continuously
After a power failure, possibly accompanied by a surge, the television will come on, but turns off, then back on, repeatedly. Occasionally it will stay on long enough to display a raster about 1/2" wide. It does this when any of the video inputs (component, vid1, vid2, etc) are chosen except the two VGAs. Then it remains on and displays "vga1" or "vga2" with a seemingly full horizontal scan. I've let it sit overnight, disconnected it from the surge protector, and tried different outlets. Any thoughts would be appreciated.
  • 1,476 Answers
You say that you disconnected your unit from the surge protector overnight. I assume it was hooked to the surge protector when the problem occurred? If so and based on the fact that you indicate that it is working on VGA1 or VGA 2 I would try replacing the eeprom. It would seem the most likely component and is certainly an easy and cheap solution to try. As techman said these sets are dangerous and you should not attempt this unless you are experienced with the proper procedures. Good luck.
Posted on Jun 23, 2006
    President:
  • 3,130 Answers
This coulkd be what we techs call a dog set to repair , as a surge can cause all sorts of problems. If your not a tech theres not just one part we can tell you could be bad but you also need to know how to test oit as these sets have no real user serviceable parts inside these sets. Also dont forget about the HI voltage these sets can store inside for a long period of time , even when they are unplugged. First thing that should be checked inside this set would be the main power supply. The fact that its trying to come on tells you i-ts probably not regulating or a short is preventing it to start up. Check all the error amp transistors as well as the referance IC. If you can get the power supply to come up with a variac. then check the verticle Output ic and see if you disconnect that if the su pply and the set starts up. If not then its most likely a problem in the HI vfoltage/sweep circuit and .or the scan power supply. This could be an easy repair but most times not. Good Luck
My lg 50LN5200 tv won't turn on, a big storm turned it off. it won't turn on. What should I do?
large power surges (many times greater voltage than normal) usually accompany a utility power outage , this can and most times will take out a devices power converter rendering it useless , have a qualified tech have a look at it , see what he thinks could be failure
always try and prevent sensitive (and expensive) electronic items from being damaged in power surges by using a surge suppressors , some of these include insurance to repair anything that's plugged into them , and always replace surge suppressors every 3-5 years , they do wear out !!
some utility's have insurance that u can purchase(extra) from them to pay for any repairs this might cause in future , ck with them 4 this
Jun 24, 2015 | LG Televison & Video
Vizio logo blinks orange/white for a minute then stops blinking. TV never comes on.
If there was a power surge, a power supply component may have failed.
Jul 01, 2014 | Vizio M550NV 55 in LCD HDTV
SONY tv won't turn on; hissing
Possible bad internal power supply unit. Contact Sony if youre still under warrenty or a local repair shop. I had a similar problem that caused mine to blow out from a power surge.
May 24, 2013 | Televison & Video
Tv won't turn on due to power surge
It's technically possible, but depends on the damage.
Jul 01, 2012 | Televison & Video
I have a Toshiba 26AV502R tv, was working yesterday and now it won't turn on? It's about a year old. What do I do to fix this?
the only thing you can try to do: unplug TV, let it "reset" for a minute or so, then plug it back in. If that won't help, means: surrender to repair service. for 1 year, even with 24/7 usage, there is a slim chance for "bloated" capacitors inside of TV's power supply, but quite a good chance of your main board failure. Now a days they quite compact, packed with high temperature producing IC chips, led-free solder, which has drawback of "fatigue" failure. Or, there might be power surge involved. In any case, except "lock up", appeal to TV repair service.
good luck,
Alex's Television,
215-806-5980.
Jul 16, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
Had a power surge into the house- the tv was not on a surge protector and i am wondering if the tv is blown out- or is there a fuse possibly that blows at a power surge?
hello kath... if the tv won't come on now the power surge fried internal fuse and possibly more. The least expensive way to get this repair is to physically take the tv to the repair shop. If they have to make house calls, the cost goes up significantly. Joe
Apr 21, 2011 | RCA HD52W59 HDTV Projection Television
No picture or sound?? status light flashes in four blinking intervals. I was told it could possibly be the lamp it has never been replaced.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet.NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Proscan PS36800HR 36" TV Logo
91 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
