Question about Rival S16RB Electric Skillet
Skillet Our skillet will not get hot enough. Even with preheating it takes much longer to cook than a regular skillet. We do like the convenience of the removable pan for cleaning.
  • Anonymous Jan 06, 2009
    My S16RB will not get hot enough to cook pancakes. I called Jarden (Rival parent company) and they sent me a replacement. Same problem. It would not get hot enough to boil water set to the max. They sent another replacement. Again same problem. Turning the temperature to 400 would only produce 184 degrees. I returned that one to them for testing at my expense. I have waited almost 4 months for results and a correction of the problem but have had no response. I am totally dissatisfied with it all. Am I suppose to go buy a different brand and write this off as a dud and go on? My first response was very good from Jarden but they have left me with an opinion of total customer neglect after 4 months of waiting with out a response.
2 Suggested Answers
  • 4090 Answers
SOURCE: skillet does not get hot enough
Essenhtially this is a Sunbeam product madse by a subsideriy named Jarden consumer solutions.
Go here tp hone or use the link.
http://www.jardencs.com/Brands.aspx?section=rival
Please rate my help++++Thanks for using FIXYA
Posted on Jun 25, 2010
I have a maytag gas stove model mgr5720adh When I use the oven during the preheat is fine it does take longer to preheat but when it maintaining the temp I start smelling gas.
Change the igniter the igniter is not getting hot enough to open the safety valve and what it does there's not enough heat on the igniter to ignite the flame of the burner
Jan 17, 2017 | Maytag Kitchen Ranges
Tip
General Tso's Tofu
Here is an amazing tofu recipe that i found online and unfortunately can\'t find the website where i copied it from. But it makes this (in my opinion) unflavored food taste like heaven.
Ingredients:
For the Tofu:
1 package of tofu
1 tbs arrowroot
3 tbs gluten-free, low-sodium tamari
1 tbs fresh ginger, grated or 1 tsp. ground
1-2 tbs canola or peanut oil
For the Sauce:
1 tbs sesame oil
1/4 cup gluten-free, low-sodium tamari
1 tbs arrowroot
3 tbs honey
2 tbs hot sauce (optional)
1 tbs canola oil or peanut oil
4-5 scallions, thinly sliced
4 cloves garlic, minced
Sesame seeds, for garnish
Instructions:
Cut the tofu into cubes. In a shallow bowl, combine the arrowroot, tamari and ginger. Whisk until smooth. Add the tofu and toss to coat.
Let the tofu marinate for at least half an hour, the longer the better.
When the tofu has marinated, heat 1 tbs of canola or peanut oil in a large skillet over medium-high heat.
Add the tofu to the skillet and cook until golden brown on all sides, about 4 minutes per side. Remove the tofu from the skillet and set aside.
Wipe out the skillet because you’re going to use it again.
In a large measuring cup or bowl, combine the sesame oil, tamari, arrowroot, ginger, honey and hot sauce, if using. Whisk until smooth. Set aside.
Heat the canola oil or peanut oil in the skillet over medium heat. Add the scallions and garlic and cook until fragrant, about 2-3 minutes.
Add the sauce to the skillet and let it cook until it thickens a bit. If it gets too thick, add some water.
Add the tofu to the skillet and toss to coat in the sauce and reheat the tofu.
Sprinkle some sesame seeds over the dish when ready to serve.
Bon Apetit!
on Oct 13, 2013 | Cooking
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
How do I season the griddle that came with my new gas stove?
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Nov 22, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Oven takes a long time to preheat
You don't list a full model number or how old this range is, or how long / how often you have this problem, but generally it sounds like the oven ignitor is not quite drawing enough amps to allow the gas valve to open regularly. It could be a low voltage related issue, but most likely is a failing oven ignitor. ( WB2X9154)
Sep 04, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Rival Electric Skillet S16G
Hi, Your skillet is either defective or someone has left it on high with nothing in it. Either way, if it is still under warrenty, I would try and return it. As there is some debate about the toxicity of teflon, I would be very careful about using this unit any further.
If you are going to keep the skillet, try using steel wool to remove the loose teflon, maybe even sanding it all off if you want, then polish with fine steel wool and use the skillet as a regular uncoated electric fry pan.
Hope this helps, and if you found this response satisfactory, please vote. Thanks and good luck.
Mar 02, 2008 | Rival S16SG Electric Skillet
Corningware Microwave
Preheat browning grill 5 minutes in microwave on high, then cook items.
Feb 03, 2008 | CorningWare Crock Pots & Slow Cookers
Rival 12x12 electric skillet
it is very dificult to get replacement parts for your electric skillet.but you can try partstore.com and see if they have a replacement part for your skillet.good luck and good cooking.
Jun 08, 2007 | Rival S12-GN Non Stick Electric Skillet
Rival S16RB Electric Skillet Logo
52 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
