Sharp XE-A20S
Someone has programmed an entry digit limit on that department. Look through the programming for departments and set the entry digit limit back to default for that department. I don't keep the department codes on hand as I never set limits. It should be in your manual. If you need one, C-tech collective have it here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A20S_operating_programming_manual.html
SOURCE: sharp xe-a20s locked up
Hi.
Yes you are right. you have logged yourself out of the machine. it is telling you to log back in.
Press 1 then CLK# or CASH#
Mark
SOURCE: I have a sharp xe-a20s cash register. When I turn
This is correct. You have bumped the clerk button and logged yourself out, so it wants you to log a clerk back on. Try pressing clear to remove the error, then 1 then CLERK (sometimes called CASH# or LOGON or CLK#)
