Question about Cyberhome DVD Recorder - DVR1600
Door will not open
I have a CyberHome DVD recorder that I got for Christmas, in 2007 the power cmes on but the door will not open when I push the eject botton.
It's the CH-DVR 1500, could I get some help.
  • charleslllrd Nov 21, 2008
    I HAVE CYBERHOME DVD RW RECORDER FOR MY COMPUTOR. I HAD IT FOR 4 YEARS IT WORKED JUST FINE UNTILL THIS YEAR, THE DRAWER WAS STARTING TO STICK SO I OPENED THE UNIT TO SEE IF THERE WAS ANYHING CAUSING THE PROBLEM. I DIDN'T SEE ANYTHING WRONG SO I REASSEMBLED THE UNIT VERY CARFULLY. WHEN I PLUGED THE DVD BACK IN MY COMPUTOR THE DRAWER WOULD'T OPEN AT ALL NOW. DID I DAMAGE THE UNIT?
    Problem Solver:
  • 3 Answers
I had a similar problem, I went back in and opened it up, took the top plate that covers the lens, opened the tray, put the plate back on, then closed the tray and it works again. With the tray closed, I think I put the top plate on the bottom piece and it was stuck on.
Posted on Feb 19, 2009
My dvd recorder makes a buzzing noise wont power up eject or play
some thing might have stuck inside your DVD player. some internal wires.. attached may cause this problem. if you are aware of the wires and if you can handle it after opening it , then just open and check. if not, i would suggest you to take it to someone who is aware of that.
Nov 02, 2010 | Cyberhome DVR 1600 DVD Recorder
The dvd door on my ch-dvr1500 dvdplayer-recorder rw will not open.
Hi there
You can open the drawer manually by taking the lid off
Mar 20, 2008 | Televison & Video
Remote control for Cyberhome CH-DVD 300 is lost.
they are stop, eject, play ,ff, rr, pause, and power.
Jul 15, 2010 | Cyberhome CH-DVD 300 DVD Player
Startup goes to Hello menu and freezes. Clock starts then goes to hello once eject or any other button is pushed
Unplug the unit, open top cover, look closely at every power supply capacitor and see , if any of them has been popped open. Replace all popped capacitors with the new once.
Nov 25, 2009 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 300 dvd player does'nt read any dvd
I have CH DVD 300 Model, i have purchased this DVD on 2007, yestarday (17/05/2009).
When i put DVD in, i cannot see any screen on TV, perviosly i can seen default screen CYBERHOME, all other things are ok, (powe on ok, eject & incert ok,) dvd is not playing after putting DVD in CYBERHOME.
pL. give solution on my mail Email ID: shankarg@iss-global.com, gudala2000@gmail.com
at the earliest.
With Regards
Gowri Shanker
India
May 16, 2009 | Cyberhome CH-DVD 300 DVD Player
Can't load disc
as there is a small gears on both the sides of the door which gets a command to spin when you press the eject button as that gears are either worn out or got craked internally or are getting blocked due to any dust collected in between .if cracked or worn out replacement is necessary.but if got blocked due to dust particles just will have to open the unit by removing the screws from its top and back body and then cleaning the gears which will be easily seen internally.
Feb 26, 2009 | Cyberhome CH-DVR1500 DVD Recorder
Power cord
Salutations chuckster197,
It might be rather hard to find parts for Cyberhome products as the company as had to close its doors.
There are a few owners forums out there that are are trying to fill in the gaps. You should be able to put "Cyberhome" or "Cyberhome Forum" in a search engine to find these sites.
I hope this helps.
Jon
Go Ahead. Use Us.
May 22, 2008 | Cyberhome DVD Recorder - DVR1600
Disc removal/ CH-DVD 300
On the bottom of the DVD player, there is an "emergency slot." I used a knife to push the botton over which manually opens the door to get your DVD out. However, I can't turn my DVD player on either. And can't figure out what the heck to do??!?!?!?!
Dec 23, 2007 | Cyberhome CH-DVD 300 DVD Player
Unable to open DVD slot
USE A SCREWDRIVER UNDER LIP OF EJECT AREA.SOMETIMES THEY SLIP OR GET OFF TRACK; OPEN UNIT EJECT TRAY THEN RECLOSE IT.SHOULD WORK
Sep 02, 2007 | Cyberhome DVR 1600 DVD Recorder
open the cover of dvr, clean the tray or replace the belt
Aug 16, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVD Recorder - DVR1600 Logo
105 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
