Question about LG 42LC2D 42 in. LCD HDTV
Green picture my picture sometimes turns green, but if i pull on the upper left corner it clears up. picture turns green again as soon as i release the tv.
  • lizzy76782 Oct 20, 2008
    thank you for your reply. I will try it.
  • Anonymous Mar 16, 2014
    upper left corner
  • 905 Answers
There is a bad connection and you will need to look to see where the bad connection is comming from exactly , and if it can be soldered or repaired ( maybe a plug or a wire loose)it might even be a wire strip that is bad , but it will have to be opened to find out
Posted on Oct 19, 2008
Picture is not full screnn only upper left corner
not real clear what you have: if you have a small picture in upper corner look in menu for PIP and with remote turn it off(picture in picture will do that)
If not let me have a better description of what it is doing.
Mar 30, 2012 | Sceptre 32 X320BVHD 32 LCD TV
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
H-4 model xc830 copier
Performing a Fault Reset 14 will reset your copier and will help to clear error codes. 1. Turn the power off. 2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button. 3. Locate the Auto Button the lower left corner of the Control Panel. 4. Turn the power back on. 5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear. 6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5. 7. Program the copier as if you were going to make 14 copies. 8. Press the green [Start] button to store the reset code. The copier will return to the ready position. 9. Run a test copy.
Jun 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
How do ya reset fuser code (H-4) Xc1044 Xerox?
  9. Run a test copy.
Nov 26, 2008 | Xerox Office Equipment & Supplies
H4 code on XC1255
  9. Run a test copy.
Aug 22, 2008 | Xerox Office Equipment & Supplies
XC-830 copier Displays fault code H-3
Give this a try , if it continues you will have to replace the fuser.
  9. Run a test copy
Aug 07, 2008 | Xerox Office Equipment & Supplies
Xerox B/W Copier XC 1044
Here you go. If you have no underlying problems this should work. If it comes right back, you have a fuser problem.
  9. Run a test copy.
Jun 09, 2008 | Office Equipment & Supplies
Meaning of Green square icon on upper left corner
I have the same camera. The green square icon appears while the camera is saving the picture. From your description, I think you were using "Shot Confirmation", and this setting was cleared during the repairs. Have you tried going into the Setup mode (on the dial) and reselecting Shot Confirmation? (p. 143 in the manual)
Jan 17, 2007 | Nikon Coolpix 5400 Digital Camera
LG 42LC2D 42 in. LCD HDTV Logo
152 people viewed this question
Computer Repairing
Computer Repairing
