Question about LG WM1814CW Front Load Washer
Tromm does no stop filling
We just moved our LG WM1814CW from my mothers house to our house using our SUV. The washer and dryer were laying on there side. I started an empty load and it just keeps filling to the top with out shutting off. there were no error codes. it was leaking from the frount seal. What can i do? is there a sensor that is not working or a reset?
Thanks
skip
    Sergeant:
    Champion:
  • 291 Answers
You got water in the pressure valve hose ,,,,, keep running in on drain till it clears or the best it to remove the top of washer, pull off the little hose and blow thru it to clear it
Posted on Nov 25, 2008
I need to force my lg tromm to drain
My LG Tromm washer has a small door on the bottom left hand side on the front of the washer. Open the door and you will find the drain filter and a stoppered, small rubber tube. Position something to capture the washer water under the small rubber tube and pull the plug.. This will drain all the water from the washer.
Aug 01, 2014 | LG WM1814CW Front Load Washer
I have a tromm wm1814cw washer .i am trying to replace gasket.not having any luck.can you inform me as to the secret. thank you
There are 2 special tools you will need to change the door gasket. Call LG and order the door spring removal tool. There are 2 of them.
Jun 15, 2011 | LG WM1814CW Front Load Washer
LG Tromm wm 1814cw makes loud noise
You will need to remove the back cover plate of the machine and locate the large pulley at the end of the drum. Remove the belt, then the pulley and you should see a bearing housing. Some models require a bearing and housing replacement, while others can simply be repaired with a bearing replacement alone.
Go here, and find the nearest Dealer for your part.
http://www.1stsourceparts.com/contact_us/branch_info.asp
Or you can try ordering direct from LG. If you are as handy with tools as you say, this should be a fairly easy job.
Mar 23, 2010 | LG WM1814CW Front Load Washer
My LG Tromm WM1814CW is not draining. I cleaned out the drain filter and checked to make sure the drain hose is not kinked and still - there is no water draining from the machine except when I pull out the...
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
Jan 26, 2010 | LG WM1814CW Front Load Washer
On my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Nov 28, 2009 | LG WM1814CW Front Load Washer
LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Jul 12, 2009 | LG Washing Machines
LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Nov 17, 2007 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
404 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
