Coputer is not running on the primary drive.
My computer is running on a seconary drive not the primary C: drive. I am running on Windows XP. How can I get it back on to the C: drive, tried the F10 function and that will not work because the computer is running on the H: drive.
  • Bodiddly Oct 19, 2008
    No it is not. Had someone fix it after I had a problem, but they didn't add anything.
  • 29 Answers
Is this a custom built computer
Posted on Oct 19, 2008
  • mrtimothyjoh
    mrtimothyjoh Oct 20, 2008
    you need to get into the bios to change the boot order. if your computer runs fine from the secondary drive then that means windows was loaded onto that drive. if so then press del or f1 f2 which ever one takes you to your bios screen and change the boot order to start from c. next you have to make sure that the jumper setting on your hard drive is set to master. out of the 3 sets of 2 pins it will be the set next to power plug end
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Multiple OS problem[Primary corrupt]
Windows XP Professional SP2
The Windows XP startup disk allows computers without a bootable CD-ROM to perform a new installation of the operating system
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
if you need more help with this post a reply
hope it helps
May 25, 2012 | Microsoft Windows XP Professional SP2 for...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
You cannot install 98 directly on your system slave drive, but there is a way to install it.
1) disconnect your primary drive
2) make your slave drive as primary.
3) install 98
4) Connect your actual primary drive again and start your system
XP records your mac id of your motherboard and 98 does not records, the other way is, you can install both the OPS on your one primary drive by creating different partitions, you will need to full format your drive first.
1) Full format your primary drive.
2) Create partitions.
3) Install 98.
4) Install XP in different drive of your same hard disk
You will be able to see both your OPS when you start your system.
Sep 18, 2009 | Computers & Internet
yes you can install vista....................without lossing your data.......
If you are running windows xp then don't install the vista where you have installed xp...........just installed the window vista in other drive
If your system is running in vista only.......then u can install the vista on that drive this will not lose your data
Aug 24, 2009 | Microsoft Windows? Vista Home Premium...
Hello I have just the other day purchased a Linsky broadband router(model WRT300N) with it I purchased 2 USB keys model no WUSB54GC-EU,on my seconary pc(next door)I have susessfully installed the software...
Are you using Windows XP on your primary PC? If yes, you dont need to install the wireless LAN monitor of the usb adapter because Windows XP has a built-in wireless monitor. Start with a clean slate by uninstalling it from Add/Remove Programs. Next, to install it properly, just plug the wireless adapter into your computer, and when Windows XP finds it, it will either look for the cd to get its driver or it will install it automatically (verify this by right clicking on My Computer >> Properties >> Hardware >> Device Manager. You should see the adapter under Network Adapters) and it should say something like "it's working properly). Once installed, go to Control Panel >> Network Connections. Right click Wireless Network Connection, click View Available Wireless Networks. Connect to your wireless router from here.
Jun 27, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Computer does'nt start
This is usually caused by a registry file that grew too large. Your best bet, assuming that you don't have the WIndows disk because it is a Dell, or another PC type that has the hidden recovery partition, is to run your system's recovery and do a non-destructive recovery that will attempt to repair the OS without damaging your files.
Beyond that, you are going to need the Windows XP CD to access the recovery console, and that have worked for somany people having similar problem.when you load the restore cd Insert the Windows XP startup disk into the floppy disk drive, or insert
the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the
CD-ROM drive if you are prompted to do so.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery
Console. ...
this will restore the missing files in the system registry.hope this helps thanks and God bless
Oct 19, 2008 | Microsoft Windows XP Home Edition
Hard Drive Failing?
It may be a virus or spyware. You can go HERE and run Trend Micro's Housecall on your PC. It's free.
You should also perform regular system cleanups and defrags on your pc.
Jun 25, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
