Question about Sony Network Walkman NW-A3000 MP3 Player
Problems changing volume & sound horrible
I recently played my walkman through a set of computer headphones & ever since the sound has been unbearably load & fuzzy. When I try to adjust the volume a message appears saying 'cannot change volume when audio output is in line out. Please help. Thanks Tom
  • 513 Answers
Your player is flipped. It thinks that it's connected to an external device, and acts as if it in line out output. When outputing to line out, you really don't have volume control, and you hear it right with the headphones, you would be missing some amplification. Try to reverse the actions that choose line output: Press and hold BACK. The Home menu appears. Press the arrows to select the settings icon(looks like a suitcase), and then press play/pause. Press the up/down buttons to select Audio Output and press play/pause. Now you should see "line out" selected. move the arrows to another setting - headphones if available, and press play/pause. Now unless something is really wrong with your player it should work. If it doesn't, use your warranty if valid, send for repair. Good luck
Posted on Jun 25, 2006
The sound on my firefox browser is low but when I listen to Window media player, it is very loud.
Try following solutions, if it works for you
To switch between speakers and headphones on Firefox,
make sure your headphones are plugged in first,
Right click on volume on the bottom right corner of your screen,
Then select Volume Mixer,
then double click on System sounds,
Click on the playback tab,
then you could switch between speakers or headphones, just select one and click "set default" and OK
only sounds in firefox will play in the headphones,
and windows media player will play on the speakers
You could leave your windows media player to play on the speakers while you listen to firefox videos in the headphones
If you want the media music player to play in your headphones also;
You have to change it in the media player program,
go to options on the media player, then look for playback devices, there should be 2 options speakers and headphones,
just pick one
I usually set the firefox audio to my headphones,
and a media player to the speakers
Please rate & vote if you like solution...
Thanks
Mar 13, 2011 | Computers & Internet
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Pin connections of J8 connector on motherboard for connecting front audio headphones and microphone. I have no idea of which pins on J8 to connect the headphones and microphone as they have never been...
As J8 can vary in usage from circuit board to circuit board, it would be somewhat difficult to solve your issue without knowing the manufacturer, model, & revision # of the product in question. However, chances are that the default settings already allow for front audio input use of headphones & microphone. Also, you should investigate your sound settings within the operating system, primarily, (& the sound settings of whichever software program in question, secondarily). Make sure that you UNMUTE the volume for the front speakers. The microphone should only be taken off of mute in the settings for recording volumes--otherwise the output (speakers/headphones) could loop back through the input (microphone), yielding a reverb effect at lower volumes & a horrible sqelch at higher volumes. A communication programs such as Skype® can help with setting the proper level of volume (gain) for the microphone for optimizing your microphone/headphone experience.
Jan 09, 2011 | Computers & Internet
My computer is not playing audio 2,not sound is
Make sure your Volume is not in mute.
Check if your speakers are connected to your PC and switched on.
Then you can try to change the Sound Settings(check Audio>>Sound Playback>>Default Device) in Control Panel.
Try to check with a different set of speakers or headphones.
You can also try to reinstall sound drivers
If none of the above seems to solve your problem, there could be a h/w fault. You could try contacting your PC manufacturer for support.
Aug 02, 2010 | ASUS Eee 4G Notebook
Nano won't play music just through my headphones-
1 Please check the headphones on any other device to make sure that there is nothing wrong with them and they are functioning normally. 2 Switch on the Nano and press MENU 3 Go to settings and go to clicker. It will show 'speakers' 4 Press the center and it will change to headphones. 5 Set it there. 6 Similarly you can adjust the volume.
Jan 22, 2010 | Audio Players & Recorders
Lowrider 360 Skullcandy Headphones don't seem to work on my xbox.
The thing you need to realize is, the headphones are not defective. Headphones cannot choose to individually make voices/game noises/music louder or quieter. Either they play audio or they dont.
What your issue is, is configuration with the xbox (the soucre FEEDING the headphones) Only there can you choose the amount of voice/game noises/music and their respective levels.
Below is a link that headphone company has on their site for the settings you need to change in your xbox.
http://www.skullcandy.com/manuals-and-drivers.html (see the second section, second option doesn "xbox settings for lowriders")
Any further settings will need to be assisted by an xbox support person.
May 16, 2009 | Skull Candy Lowrider Headphones
Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
Apr 05, 2009 | Sony (Personal Audio) Walkman AM/FM Stereo...
Sony Walkman Video NWZ-S616F MP3 Player, low volume
go into music settings and go to volume limit and turn it off or it might be the headphones or if it goes up to 30 thats the limit its supposed to go up to.
Mar 23, 2009 | Sony Walkman NWZ-S616F MP3 Player
Can't increase volume
Hold the Menu button until u see: Search.
Then go down to AVLS: then it will say "on" next to it. hit vol. up, then the down button, play/stop.
Finally hit "Menu" again to go back to music
Nov 02, 2007 | Sony Walkman Bean NW-E305 MP3 Player
Sony Network Walkman NW-A3000 MP3 Player Logo
144 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
