Question about Magic Chef CYG4000AWW Gas Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Magic Chef model#CYG4000AWW Gas dryer runs but squeks loudly. After 10 minutes the dryer will shut off. We wait about 10 minutes, and dryer will turn back on. Thanks for any help you can give me. donnah1135@aol.com
  • 61 Answers
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Posted on Dec 26, 2008
Magic chef dryer making very loud noise as it turns, how to get the bottom off
No need to take the bottom off - the top, front, and back come off - if the noise is a rather high pitched squeak the pads on the drum are worn out, if it sounds like a squeak but more metallic/raspy sound check the motor bearings, also check the drive belt.
Oct 13, 2014 | Dryers
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
Aug 07, 2014 | Magic Chef CYG4000AWW Gas Dryer
High pitch squeaking noise throughout the whole drying cycle, getting worse.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 03, 2011 | Magic Chef CYG2000AWW Gas Dryer
Dryer makes loud grinding/rubbing noise when operating
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 03, 2010 | Magic Chef CYG3005AWW Gas Dryer
Gas Dryer Stops after 30 minutes.
Your problem is caused by a motor overheating causing its internal overload to shut it down until the motor cools. If you truly have thoroughly cleaned all interior areas of your dryer and the vent leading from the house to the outside there are only two possible problems that can give you this failure.
  1. The dryer motor bearing is failing (tightening) causing the motor to be harder to turn. This will force the motor to draw more current to keep it running and this generates more heat than usual. The additional heat opens the thermal safety on the motor until it cools down. Motor needs to be replaced
  2. The air holes at each end of the motor are clogged with lint that needs to be cleared out. The body of the motor may also be coated with lint. Both these conditions will cause the thermal overload in the motor to open until it cools. Motor needs to be fully vacuumed.
Good Luck.
Nov 12, 2009 | Magic Chef Dryers
Dryer was making noise each time it rotated. Next
HI, seems to be a busted belt here. have it replace asap if possible.
Jun 22, 2009 | Magic Chef CYG4000AWW Gas Dryer
Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
Jun 17, 2009 | Magic Chef CYG4000AWW Gas Dryer
Majic chef dryer rollers making noise. cannot figure how to get inside of dryer exposed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Magic Chef CYG4000AWW Gas Dryer
Gas dryer runs sometimes, not others.
heatman101
dhjhdf
Feb 15, 2009 | Magic Chef CYG4000AWW Gas Dryer
Magic Chef CYG4000AWW Gas Dryer Logo
455 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
sonic boom...
sonic boom...
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
