Question about Canon Speedlite 430EX TTL Flash
430EX Hi- The text on my 430EX's LCD won't stop blinking.  In any flash mode, the text just constantly blinks.  It reads "ETTL M Zoom 14mm" and I don't seem to be able to make adjustments except to the flash mode.  Am I stuck on something, or should I take it to be repaired? Thanks, Derik derikbrendanmoore@gmail.com
    Problem Solver:
  • 12 Answers
Your flash has a diffusion panel in front, make sure its in all the way
good day
yitzy
Posted on Oct 29, 2008
  • dbdw
    dbdw Jan 15, 2014
    Thanks Yitzy! That helped me too! :)
Wow...! That is sooo the fix... I didn't realize it because I use 3rd party diffusers on all my flashes which covered the internal diffusion panel...! Turns out it was sticking out just a hair but enough where I had that same blinking "ETTL M Zoom 14mm" issue. Thanks Yitzy..!
Posted on Mar 26, 2009
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Text is blinking on my 430ex lcd screen zoom --mm. How do I get it to stop?
Check the diffuser is fully retracted. Pull it fully out then all the way back in.
Apr 10, 2014 | Canon Speedlite 430EX TTL Flash
Message symbol blinks on Nokia 3110c!
i think thats what they are designd to do so you dont miss any important messages
my nokia 6300 does the same thing
hope it helps
Nov 27, 2011 | Nokia 3110 Cellular Phone
Hi, I have a Canon Speedlite 430EX II. I use it with Canon Rebel T1i. I don't really know a lot about using an external flash, I'm just an amateur I must say. I just always have it on automatic mode and...
Okay big breath, The Rebel T1i controls the flash (one reason you turn the flash on and off that's it) so you may have simply switched metering modes, with flash you should be on Evaluative mode.
Another thing is the camera may have been programed for TTL in the Menu E-TTL is the "normal" but if it's changed then the changes stays until you change it back.
I think it's the metering mode but if not you need to go into the camera Menu, Flash Control, External Flash, Flash Mode then select E-TTL. I found this all in a PDF manual of the Rebel T1i pages 139 through 141.
Hope this was a help.
Feb 15, 2011 | Canon Speedlite 430EX TTL Flash
Zoom--mm blinking and can't change mode
Your zoom motor is probably stuck. Remove the two screws on the front side of the tiltable head. Pry off the two tilt caps using a small flat head screwdriver (they are glued on). Remove the 4 screws found under each cap. Now you can separate the two sides of the head and take out the two lenses (remember exactly how the lenses were positioned). Try pushing the flash in or out (it should move with a little force). See if the flash now responds before reassembling.
Mar 21, 2010 | Canon Speedlite 430EX TTL Flash
LCD display on minolta autometer 3 constantly blinking
I can't help but have the same problem! battery OK. Can change ASA/ Time but when I press button to take a light reading the display flashes for about a minute. did you ever find a solution?
Mar 01, 2009 | Cameras
Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
Aug 07, 2008 | Canon Speedlite 430EX TTL Flash
Canon speedlite 430EX
Make sure it is not set to manual 'M' on the display. To get it to shoot in ETTL (Through the lens) press the mode button and it should read ETTL in the top left corner. This then means that the light is metered thorugh the lens and you are not relying on the manual settings.
Hope that helps. I had the same problem when i first got my.
By the way a brilliant all round bit of kit. I have traveled the world to some fairly extreme temps and got it wet (Rain, humidity, sea spray to deserts and serious dust) All good.
Good luck
Apr 14, 2008 | Canon Speedlite 430EX TTL Flash
Canon 430EX Flash
I have a 430ex and S5, I don't think the zoom head will move without being mounted on a camera.
If the flash test fires ok, then it should be fine.
Oct 16, 2007 | Canon Speedlite 430EX TTL Flash
Canon Speedlite 430EX TTL Flash Logo
1,240 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
