Question about Zenith IQC50H95W 50" Rear Projection Television
No Power Plugged in, will not turn on. Fuses check out ok. Transformer? Any help would be GREATLY appreciated. Thanks
  • dhunt03 Jul 08, 2008
    same problem w/ my WD-52725 62". No power.  It just started this behavior this week.  I've had the TV about 3 1/2 years.  I can press the reset button and all is well until I turn it off, then we go through the same process...any ideas would be helpful...
  • 1,476 Answers
The most common problem with this symptom is a shorted Horizontal Output Transistor. Usually the flyback and or yokes are partially shorted also and caused the transistor to fail. Unless you have experience working on TVs they are complicated and dangerous and should be repaired by competent technicians. Remember that this is only the most common problem. Your problem could be just about anything from a bad eprom to a shorted component and everything in between. If you checked the fuses and they are ok it sounds like it's time for a tech.
Posted on Jun 23, 2006
Fuses on top of battery
Check all fuses but the PCM could have blown. Need to check for codes. It's a good start
Oct 14, 2009 | 1999 Volkswagen Beetle
No Power, Will not turn on.
It depends on a model of the receiver. If there is no any lights check standby power supply. You can find it by looking for a small transformer (1" by 1" approx.). Standby power supply usually provide 5 volts ( sometimes 9v or 12v). Look at connectors close to standby power supply which has a pins marked as 5STBY or STB5V etc and check voltages. If there is no standby voltage repair that power supply
Aug 09, 2009 | RCA Audio Players & Recorders
Misubishi ws55513
you may want to check the power transformer you may have a bad connection or it may be bad but be careful it is a high voltage area.
Nov 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have a pioneer vsx515-k 6.1 surround receiver that I like very much, and would like to see if I can get it fixed. There was a car accident that ran into a power pole in the neighborhood and knocked out...
hello my friend usually this kind of devices protects itself in a blinck of a second and you dont see anything wrong but take a look aorund the transformer,the fuse resistor the value is about 1 ohm or less you need to know some experience how to test a transformer fuse etc....i hope be lucky. saludos
Nov 18, 2008 | Pioneer Audio Players & Recorders
RCA TV
replace the fly back transformer,thanks.
Nov 08, 2008 | RCA F32650 32" TV
Tv wont turn on
ok is in shut down mode kine of proteccion some of the fuses are pico fuses but you may have problem with convergence IC's that what I' check first if that is ok go to HVT .. if U still have problems e-mail me
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Unit is dead....
The power supply is the first place to start.
Is there a transformer? Check to see that there is AC on the primary & secondary of the transformer.
If no AC on the secondary, then the transformer is bad. If AC ok on the secondary, then look for a bad rectifier diode/module and/or regulator module. There might also be fuses on the DC side of the power supply.
If the unit is completely dead, it's most likely a power supply issue.
Please let me know if I can be of further assistance to you.
- Jim
Feb 08, 2008 | Panasonic WV-CM1020 Television
Samsung HCN4226W 42
Check to see if you have the 117 volts you need to power the Flyback Transformer. You can test this at the connector labeled CN801 at TP61 and grd. If you do not have power here check the fuses around the T801S Transformer. They are little green components that look like resistor and labeled with an FD.
Nov 05, 2006 | Samsung HCN4226W 42" Rear Projection...
Zenith IQC50H95W 50" Rear Projection Television Logo
160 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
