Question about Apple iPod MA446LL/A MP3 Player
External hard drive and ipod
If i have an external hard drive and download my music on that external hard drive. would it be a problem with me using my ipod to upload from there. would it be a wise idea to do that.
  • 77 Answers
It really doesnt matter, you will just have to have the hard drive plugged in when you sync you ipod or want to listen to music with your ipod. The only thing i have to say about it is if the external hard drive is if its connected to your computer with a USB rather than a firewire, then it might be slower to load than if you keep it on an internal hard drive. But it will work and wont be very slow, just slower.
Posted on Oct 19, 2008
MY USB port says reading when i connect a USB drive. WHy?
ANSWER: The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION: You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Jul 15, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
When I connect my usb to my ipod it just says "reading"..
ANSWER:
SOLUTION:
Good Luck!
- Chris Proia
Apr 09, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
When connecting iphone in usb port, display stays reading and nothing happens on dual xdm6350
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Mar 23, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
When I plug my iPod into the XDM6350's USB jack, it keeps saying "Reading," and never goes any further than that. I've given it a really long time, though I don't have that many songs on my iPod, but it...
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Aug 03, 2010 | Dual Electronics XDM6350 Car CD/ MP3...
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Ipod classic sync error message
first reset your Ipod from advanced settings.. Upload the library on Itunes from ur external HDD and try sync again.. it should work!
Feb 04, 2009 | Apple iPod nano 3rd Generation
How To Practically Store items into my Iomega external hard drive
ok, for starters copy the whole folder that you have pix, doc, mp3s etc and paste to the external hd....now for itunes change options of storage to the external drive...............as long as you just checked the info is really on the external...you can than delete it from the laptop............for limewire, bearshare or whatever software you are using in options you will be able to switch where you wish to store or download to....note do not sync ipod..........
Jan 01, 2009 | Iomega Silver Series 320GB 3.5 External -...
Ipod music is gone, but still says it has stuff on it
If you do this through itunes, it should be okay. The trouble is everytime you want to update your ipod, you will need to connect it with itunes and itunes will need to have your existing library that you created for you ipod to perform a quick and troublefree update.
If you are going to get an external harddrive you will need to re-direct where itunes is saving your music and video files. Because itunes will be using your internal harddrive for the system files (that is where windows is), it will automatically save the music to your internal drive. I suggest reloding an updated version of itunes from http://www.apple.com/itunes/ here and when asked where to install it, redirect it from C:programfiles.......to your external harddrive. This way the itunes music folder will be on your external harddrive.
Hope this helps
Nov 02, 2008 | Apple iPod MA446LL/A MP3 Player
Copying music cd to external hard drive for ipod
ok...you are connect via usb? when using limewire, window media or itunes,,,,go to options on all them and change the directory where you like to store and retrieve files from...now for the files that you already have on the primary hard drive....go to my computer..you see both drives internal (is your c) and the external is ?) find the music on the c drive ..open it..cut & paste (or click & drag) to the new drive ....to copy this music onto your ipod...make sure you have the latest itunes version (WWW.APPLE.COM) once you have this on the desktop let it scan for all the music on pc....now plug ipod to pc...20-30 seconds your ipod will show up on itunes...look on the bottom of itunes left side (u see the ur ipod)...look up and click on the music folder on pc drive and all the music should now be showing too...click on that same folder drag down to the ipods music folder.......let it load up...it might take awile depending on how much you got .....not never ever pull ipod out always eject the ipod .......then unplug it............................
Apr 10, 2008 | Western Digital My Book Essential Edition...
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
