Prescott 800 P4561 Celeron 2.8 DDR400 What is the best compatible ram i can install
SOURCE: Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Posted on Dec 28, 2008
DickCanFixIt
  • 948 Answers
SOURCE: REPLACE FAULTY CPU CELERON 3.06GHZ WITH PENTIUM 4 CPU
Your motherboard specs are at http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000152
Looks like you could go up to a 3.8GHz P4, make sure you get a fan that will cool it properly.
Amardeep46
  • 129 Answers
SOURCE: does my computer compatible to upgrade RAM?
Yes. It should easily adapt a 1GB Ram. The 32bit processors can genarally take upto 3GB of RAM
Posted on Feb 22, 2009
  • 2692 Answers
SOURCE: download driver prescott 800 audio driver
Dopwnload for Your motherboard drivers
http://www.mercury-pc.com/downloads_list.php?productid=644
Posted on Mar 01, 2009
  • 2692 Answers
SOURCE: vga driver mb asrock 775vm800..
Here iss the link to the Asrock download you requested:
http://www.asrock.com/mb/download.asp?Model=775VM800
Posted on Mar 11, 2009
Need prescott 800 ddr 400 sound card drivers
ITALIANO
Sceda madre ASROCK Prescott 800, FSB 800/DDR400 Dual Channel
Comme deve ataca PANEL1
POWER SW o o
RESET SW o o
HDD LED o o
POWER LED o o o
Grazie
Nov 18, 2010 | Asrock P4I45E-R3 P4 845E FSB800 DDR400...
ASUS P4S533-MX MOTHERBOARD FAILED TO RECOGNIZE DDR400/DDR333 RAM
In you case compatibility is your problem or your memory needs a clean up. First clean up the memory's pins. Use a pencil eraser. Then try only one by one so that you will know if there is a problem in each memory. Insert one of the memory then turn on your PC. If it boot up or it is okay try the other one. Then if it is also okay, try both of it inserted and turn on your PC. If it not okay there is a compatibility problem. Make sure the brands are the same so the compatibility are never be a problem.
Mar 10, 2010 | ASUS P4S533-MX Motherboard
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
What is the best processor for an a1320n?
i think this one Pentium D 900 series Dual Core (Presler)
but i prefer to use the Quadcore...any edition of quadcore processors
Dec 04, 2009 | HP Pavilion a1320n (882780261747) PC...
Compatible processor and memory for p4vp-mx
Socket 478 for Intel Pentium 4/ Celeron up to 3.06 GHz+
- Intel Hyper-Threading Technology ready
- New power design supports Intel next generation Prescott CPU!
2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Oct 16, 2009 | ASUS P4VP-MX Motherboard
Asrock fsb800 prescott 800 motherboard driver
hi guys have a good day hmmm i just wanna ask you... if you dnt mind.. how can i download Asrock fsb800 prescott 800 motherboard driver setup??
Oct 08, 2009 | Asrock P4I45E-R3 P4 845E FSB800 DDR400...
SY-P4I865PE + Dragon 2 v1.0 locks up while running XP with 3.0E P4
I would say ram. Most the time you have lockups is because of a bad ram address. The system will run for a while till you fill up enough resources to reach the bad ram address then the system will lock up. The funny part of your problem is that it doesn't happen with the other CPU. But I don't think the DDR400 ram was designed to be used in systems with a Prescott CPU. The motherboard may accept the ram and the CPU's all right but the Prescott was a pretty powerful CPU for it's time and I think most of the systems it was designed to run in used a lot faster ram.
Jun 01, 2009 | Soyo SY-P4I865PE Plus DRAGON 2 v1.0...
Can I put to much RAM in the motherboard for the Processor?
That additional RAM will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Jan 13, 2009 | Intel (C733) Celeron A, 700 MHz Processor
No power
1st of all change ur power supply may be it is coz of it coz if da fan is not spining then i am sure there wud be sum problem of power supply n as u said it was returned n tested good by the owner then i am sure u mite have some problem in power suppy n i prescribe use some good quality of ram like kingston if ur a gaming freak!
Nov 14, 2007 | Biostar P4VMA-M Motherboard
Processor compatibility
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
SEE 4 YOURSELF
http://valid.x86-secret.com/show_oc.php?id=156822
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
512 people viewed this question
David Payne
David Payne
