Question about Toshiba 27DF46 27" TV
Quit working We hooked this up and finally got it to play a DVD, but a couple of months later we went to watch another movie, have only used it to run the surround sound through the stereo, and nothing! Won't play a DVD, VHS, nor show a menu or TV picture to save it's soul. We reset it, checked all the connections, everything we can think of, and nothing. Any other hints? Using Comcast DVR, Sylvania TV, old sharp audio/CD/tape surround sound unit.
snakehead
  • 1074 Answers
SOURCE: No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Posted on Mar 23, 2007
SOURCE: No picture, only sound
The set has a shorted vertical output IC, probably a TA8427k. The capacitors around the heat sink of this IC dry out and cause the IC to run hot. The correct repair is to replace the vertical output and the electrolytic capacitors near it. Also use 105 centig instead of the original 85 centigrade. The is some time a pico fuse or current limittng resistor which must also be replaced. This a common problem with Toshiba and is not a bad picture tube. The usual cost of this repair is around $120-150 depending on the integrity of the technician. Scrivitron
Posted on Jun 29, 2007
MJS_1
  • 150 Answers
SOURCE: Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
Posted on Apr 24, 2008
  • 71 Answers
SOURCE: no sound or tv signal
Probably need the TUNER either fixed or replaced.
Posted on Apr 27, 2008
  • 124 Answers
SOURCE: using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Posted on Oct 01, 2008
I just used my Sony minidv camcorder yesterday with a mini dvd +R disc and it worked fine. Turned it off while not in use and went to use it again later and it reads disc error. This is the second disc...
VIDEO mode You can play back the disc on most of DVD players if you finalize it.
VR mode You can edit, delete pictures, or divide movies on your camcorder However, the disc can be played back only on DVD players that support VR mode when you finalize it.
Apr 05, 2010 | Sony Video Cameras
My PS3 will play PS3 games sometimes. It quit
sounds like a dead Laser they are a dual laser will read DVDs n CDs but wont read Blueray movies or PS3 games Laser might need replacing
Oct 19, 2009 | Sony Playstation 3 (PS3) Console
Jvc dr-mv78
The laserunits in some JVC sets are verry bad,for some sets there are updated units available incl software.
Aug 27, 2009 | JVC DR-MV7 DVD Recorder/VCR
I recently bought a portable dvd for the car and it will not play the movies. I am a grandmother and did not use this item right away. My daughter in law hooked it up and about a month later I took the...
so you how long did you have it hooked up and how long have you had it peroid it might be a power problem when it stops playing does it shut off all the way
Aug 07, 2009 | Televison & Video
I have wasted 4 hours with 1 of your so called (experts) i want answers not excuses
Don't know if I can help or not, but this what I do.
I've downloaded the DIVx player and converter software (free) to my computer. I can download mpeg, avi movies, etc, and convert them to DIVx format if I need to. The DIVx player has a 'burn' feature that is fast and burns them in a DIVx format. My old DVD Recorder will not play DIVx format but my 'cheap' Phillips will. I just keep it hooked up to my old DVD recorder through the front RCA input jacks. When I want to play a DIVx movie and watch it on the TV, I use the cheap Phillips player. I have to change the input on my old DVD Recorder to 'Front Input. I usually record the movie on a DVD R in my DVD Recorder while I'm watching it if I want to keep a copy to play later on the DVD Recorder. Most of the time, I burn the movies to RW DVD and erase them later.
I don't remember the web site for the DIVx players and converters, but you should be able to find it with a search.
Hope this helps.
Jan 16, 2009 | Televison & Video
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Dvd player reads no disk
Hello thank you for choosing FixYa.com for your answer My name is David.
It sounds to me like Its in need of cleaning the dvd lenses collect dust over time
of no use and will cause them to not read properly try running a dvd cleaner disk in it you may have to run it a few times but it should work if it doesnt you can try to take it apart to get to the lense and clean it with alcohol and a cue tip lightly dipped.
Nov 07, 2008 | Jwin JD-VD509
Need Help
Sounds like you have a loose cable. Check that the connection is really in well. If the problem continues I would get a new set of cables, especially if you are using the ones that came with the receiver or dvd player.
May 05, 2008 | Audio Players & Recorders
Movies on my recorded discs freeze after a few minutes of play
Sometimes this unit gets "confused" - not sure why -- but try first using a CD cleaning disk and let it start and stop a couple times (sometimes lens gets dirty and does this) - if that doesn't help then try unplugging unit and leave unplugged (from wall socket) for about 30min then plug in, set local time and then see if the disks play okay - sometimes this "resets system"
Jan 20, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Toshiba 27DF46 27" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
