Question about Philips Magnavox TS3260C 32" TV
Philips Magnavox 32"
I also have a Magnavox 32" that seems to shut off because it has no sound and no picture. But the the red button that indicates that the television is recieving power is still on. If I change channel they both come back (sound & picture) but it's not long until it happens again. I have had the repair man look at twice and he can't figure it out. Can anyone help me?
    President:
  • 3,130 Answers
Sounds like the PLL IC or the tuner maybe going bad??. You didnt say that by NO picture NO sound, is there any light on the screen at all?? You said when you change channels it comes back alive for a bit.? This is the indication that its a tuner or related circuit problem . Now first off +these sets do not have any user serviceable parts inside them as they are all solid state and soldered in and then you also have to deal with the HI Voltage saftey issues. This is not a reapir You should attempt to do on your own as a pro should assist you in this repair. Good Luck
Posted on Jun 23, 2006
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
How do I program a Philips universal remote rc19041003/01 to my Philips magnavox tv
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Setup codes for Magnavox are:
    0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
May 01, 2012 | Philips Televison & Video
Need the universal remote code for the phillips dfr 1600
Hello
Three digit codes for Philips are
PHILIPS Codes: 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
philips magnavox are:
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
Four digit codes for philips are:
PHILIPS ........... 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
PHILIPS-MAGNAVOX ..... 0062 0204 0207 0183 0226 0288
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
May 02, 2011 | Audio Players & Recorders
No remote have universal remote what are codes for magnavox sdtv
Hello
You haven't specified details about your Magnavox. There is Philips Magnavox and Magnavox. Anyway I'll give you codes for both Philips magnavox and Magnavox.
MAGNAVOX CODES
Three digit universal remote codes are
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 089/ 133/ 163/ 165
Four digit universal remote codes are
PHILIPS MAGNAVOX
Three digit codes are
183/ 184/ 208/ 213
Four digit codes are
Direct Code Entry
Mar 03, 2011 | Televison & Video
How do I find out the code for a Magnavox TV?
Hello
Three digit remote codes for Magnavox are:
Four digit remote codes for Magnavox are:
Four digit remote codes for Philips Magnavox are:
Three digit remote codes for Philips Magnavox are:
183/ 184/ 208/ 213
Direct Code Entry
OK.
Feb 02, 2011 | Olevia Televison & Video
I have lost the manual for my Crest model Po5094-2 remote. I need the code for Philips model 29PT468A TV. Can you please help?
Hello
four digit remote codes for Philips are:-
Four digit remote code for Magnavox are:-
Three digit remote codes for Philips are:-
Three digit remote codes for Magnavox are:-
NB: Switch OFF and switch On the tv with its front panel power switch each time before gointg to an other code.
Direct Code Entry
Ok
Jan 15, 2011 | Philips Universal PH301S Remote Control
I cannot find the code for my magnavox tv. can you send me the possible remote control codes?
Hello
Three digit universal remote codes for Magnavox are:-
183/ 184/ 208/ 213
Four digit universal remote code for Magnavox are:-
Four digit universal remote code for Philips are:-
Four digit universal remote code for Philips Magnavox are:-
Direct Code Entry
OK.
Dec 07, 2010 | Philips Magnavox 27MS343S 27" TV
No sound, no picture. tried unplugging and plugging back in...same problem. the green power light just keeps blinking 14 times over and over again. tv is around 11 yrs old...philips magnavox 32" smart...
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Oct 25, 2009 | Philips Magnavox TS3260C 32" TV
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Philips Magnavox TS3260C 32" TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
