Question about Gateway MX6445 Notebook
PASSWORD ON STARTUP
How can i fix my MX6445 It's asking me for a Password and will not Boot How Can i fix this ?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    is this a new situation with the password?
Asus s200e bios startup
do you mean the windows login password or the drive password? if it is happening before windows boots up, it is easy to fix, just open the laptop and short the internal battery for 5 seconds, that will wipe out all system password, but you have to reconfigure the bios settings,
Aug 14, 2014 | ASUS VivoBook S200E-RHI3T73 Laptop...
It crashes and asked me to reinstall it when I did that now it will not install at all.
If the problem lies on Windows this can be repaired. First, If you are using Windows 7 or Vista, we can try to launch startup repair from the advance boot options menu. You can access this through tapping F8 right after you turn the computer on. Tap F8 until you get to the advance boot options menu. Choose "Repair your Computer" and this should guide you on how to do the startup repair.
If you are using Windows XP, we need to try to boot to safe mode and see if you can boot the Operating System from there. To do this, it's the same drill, tap F8 repeatedly on your keyboard once you turn the computer on until you get to advance boot options menu. Choose safe mode and press enter. This should load the operating system to safe mode. If you are able to boot from here then that means one of your "drivers" has failed the OS to boot normally. If all of these fails, We can try to repair the Operating System by booting using your Restore CD or your Operating System CD from the CD-ROM drive. Reboot the computer and press F12 (or whatever it is that makes you choose to boot to CD) while seeing the pc manufacturer's logo, this should give you the options to boot to CD-ROM. It will give you a quick prompt of "press any key to boot to cd..". Make sure you press the space bar during this time to initiate the boot from CD-ROM.
For Windows XP, Once the Windows Setup loads, Choose "Recovery Console" to repair your computer. Just choose the installation you would like to repair (normally it's number 1) then it will ask you for the administrator password. By default, the password is blank, but if you set a password for admin then use that password.
Once you get to the prompt, Type this command. "CHKDSK /R" (without the quotes). It will initiate the repair for your OS. This might take an hour or so. Just wait for it to finish and it will automatically reboot your computer. Let the computer computer reboot normally. You should be able to get to your normal windows screen back.
For Windows 7 and Vista, do the F8 and choose Repair your Computer, Choose the installation you want to repair then choose command prompt. Type CHKDSK /R and that shoudl initiate the repair for your OS. Most of the time, the "startup repair" should do the fix for Vista and 7, but just in case it fails, do this step.
BTW, these repairs are designed to repair the OS without you losing the data you have on the pc.
Hope this helps. Good Luck.
Aug 22, 2011 | Computers & Internet
Asks for password before booting up.
Hi
You can bypass this. When booting up, enter your BIOS setup (usually by pressing the F2 key at the appropriate time).Locate the BIOS Password section and turn the ON STARTUP password to off.
Also check this link if it helps:-
http://www.technibble.com/how-to-bypass-or-remove-a-bios-password/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | Computers & Internet
I can't remove the deep freeze on my computer...
point the mouse pointer on the deep freeze icon on the lower right of your monitor in the startup then hold shift then double left click it will ask for a password if you did not put any password just press enter then you can choose boot thawed.deep freeze can only be uninstalled if its in the "boot thawed mode".
i hope this helps
Mar 24, 2011 | Computers & Internet
Forgot password for startup just has black screen asking for a boot up but dont know how to get around it
boot up ur computer,press f8, choose safe mode with command prompt. choose administrator. in the dos environment type (control userpassword), it tells you to enter new password.
Nov 14, 2009 | Compaq Presario Notebook
ACER 5100 BIOS PASSWORD
If your son used the edata security and used both passwords. you can either ask him for password or change the boot secuence to boot to restore disk and restore back to default..which defaults to NO PASSWORD set.
Dec 04, 2008 | Acer Aspire 5100 Notebook
Toshiba
your laptop startup password is store in BIOS so if you want to
remove password so open laptop and remove button cell for 5 to 10 minute and insert button cell
Mar 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Gateway MX6445 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
