Fan noise My Williams wall furnace unit was installed summer of 1964 and the rubber mounted fan is making noise as it is wearing out the rubber coupling. Need new fan as fan & coupler are one piece.
  • 1,420 Answers
If it has been working flawlessly since 64, give it a break and replace the whole unit with something more efficient and safe. 44 years has got to be a record!
Posted on Oct 21, 2008
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Installed new wall heater and thermostat and pilot is on but heater will not come on?
What about thermostat wire? What ya got 2 wires right? Touch them together she supposed to ignite the flames then after a few minutes the fan kicks in on fan models. You got the knob on the gas valve turned to the "ON" position?
Nov 07, 2011 | Williams (5009622) Ceramic Gas Wall...
How do you perform an electical test on the "automatic fan switch" in a Williams wall furnace blower accessory? Part number is P-322395. Everything else including the two-speed switch and fan...
disconnect power from fan. use an ohm meter should be open when cool and closed when hot. you can do same with 110v but be carefull. 110v to one side when cool and 110v on both sides when calling for fan.
Feb 09, 2011 | Heating & Cooling
How can I install the heater?
Can you please describe the electrical specifications on the unit and in the manual (i.e. amps, electrical phase (single or 3 phase) and voltage requirement)? This will dictate the install.
Does the unit have a motor or fan?
Dec 28, 2010 | Williams 3003622 Ceramic Wall Mounted...
I purchased a side by side SBDT520 in Australia in December 1991. I love this fridge other than it has become much noisier over time. I am guessing this is the compressor. Amana is no longer available in...
The noise may be due to extermal factors, like condenser fan or compressor fastenerrs coming loose. Make sure the compressor and fan/condenser housing on the bottorm back side of the unit is clean and thight. If the unit is working fine. maybe all it needs is a little maintenance.
Don't forget to rate this post! Good Luck!!
Jul 26, 2010 | Amana 22.6 cu. ft. Side-By-Side...
High Pitched noise coming from Williams Wall Heater
open it up and you'll see it while its running sounds like fan bearings or fan misalignment may need a new fan motor. if you replace the fan though make sure all power is off before disconnecting
Jan 24, 2010 | Williams 3003622 Ceramic Wall Mounted...
Our frig is making a loud noise every 40 min.
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge. If it doesn't seem to be coming from the compressor you have two fans, one in the freezer and one near the compressor which could be noisy from hitting ice or wearing out.
Dec 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lenox Gas Furance Summer Fan Not Working
Just curious, there sometimes is a safety switch on the door to the fan unit so no one gets hurt opening it to change filters ...etc... make sure all the doors are on tightly
Jul 30, 2009 | Dryers
Williams wall furnace no longer adequately heats home
A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
Aug 31, 2017 | Heating & Cooling
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
