Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Right rear wheel
There is a clicking noise in the right rear wheel at each tire revolution. Any suggestions on how to fix it?
  • 118 Answers
You may need to be sure all the bolts are tight on the wheel, and that there is nothing stuck in the tread. is it a metallic or rubbery tick?
Posted on Nov 27, 2008
I have a clicking noise in the right rear of my 2005 Mercury Grand Marquis. It sounds like it clicks in time with the tire rotation
There are brakes shoes inside your rotor , they are for the emergency brake, lightly apply the e brake see if it changes the noise it may go away after you take. It off, rust builds up in ther
May 04, 2015 | 2005 Mercury Grand Marquis
2004 pontiac sunfire wheel noise. My car started with the front right cv axel going bad now there is a very annoying knocking sound comeing from right rear wheel it kinda sounds like something banging...
If the tires are bad i would suggest to start there , may try a ballance on the better tires . As for the squeaking brakes they may be worn out or have dust/rocks in them which can be inspected when you deal with the suspected bad tires
Dec 26, 2014 | Cars & Trucks
My girlfriend has a 2003 ford explorer. As she is
If this vehicle has an independent rear suspension /rear wheel drive then the click noise most likely will be from a failing cv joint of the axle shaft.
Oct 19, 2014 | 2003 Ford Explorer
Avigo extreme electric scooter
Something is hitting a component as the rear wheel turns one revolution. Inspect the rear tires/wheel for a foreign object that had lodged into the tire or wheel. If the noise is constant, a nut or bolt connection had loosened. Re-tighten the connection with pliers or an adjustable wrench.
Nov 24, 2013 | Avigo Kawasaki ATV - Blue
2011 camry noise left front wheel when turning
Is it a "clicking" sound?
3 clicks per tire revolution?
It may be a worn out CV joint but on a 2011?
Is it a "grumble/rumble" sound?
Would you call it a "squeak"?
Can you describe the noise,please?
Mar 07, 2013 | Toyota Camry Cars & Trucks
Right rear tire making clicking noise when going forward
is the tire flat? Have you physically taken the wheel off the right rear and inspected the tire for screws, metal pieces, rocks or other things stuck in the tire? Go do that right now..and see if something is there.
Jun 09, 2012 | 2001 Hyundai Sonata
I have a saturn Vue 2003 with 150,000 miles. there is a loud humming noise when driving coming from the rear of the vehicle. I have rotated tires and balanced. Tires have 65% more wear to go. Muffler...
Based on your description: 150K+left rear slowed down much quicker than the right +/ and the humming noise, there is a great possibility that the Wheel Bearings will have to be replaced.
Aug 18, 2010 | 2003 Saturn VUE
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
254 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
