Question about Sherwood Audio Players & Recorders
I have a Sherwood RV-8070R, Audio output has started to crackle. Problem subsides slightly when left set to a specific volume, but starts again as bad as ever when volume is changed. I have a technical backgound and am willing to change componets if I new which ones had failed. Please Help.
  • Sherwood Master
  • 5,318 Answers
As it is effected by the volume control the trouble is in the output stage. Check resistors first then ceramic caps then look at transistors or IC's.
Posted on Feb 20, 2009
Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
Jun 19, 2010 | Sherwood RV-4050R
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Sherwood RV-8070R, i can t switch it on
May 13, 2009 | Sherwood RX-4109
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Dec 25, 2008 | Sherwood R-945 Receiver
Hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Nov 23, 2008 | Sherwood RD-6500 Receiver
Pioneer deh p7500mp
definitely a heat problem. There is a chip (or set of chips, perhaps audio output chips) that work fine when cool, but when they are hot they start to fail. Common problem with IC's. Heat is not a friend of these devices. Time to get it repaired or get a new one, depending on cost of course. Also, do you have an amp attached? Perhaps the amp is the device with the failing IC's.
Aug 09, 2006 | Pioneer DEH-P7500MP CD Player
Left channel out
probably I would say no. Unless you know how to read a schematic or know how to do certain small static checks on the output devices and the drivers as well as the power suppy feeding these devices.
Apr 05, 2006 | Sherwood RX-4103 Receiver
281 people viewed this question
Top Sherwood Audio Players & Recorders Experts
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
