Question about Xerox Office Equipment & Supplies
Phaser 8500ND No screen display
    President:
  • 2,072 Answers
Call 1-800-835-6100. There is a known problem with that display. Xerox should send you one free of charge. Those are known to be defective.
Posted on Oct 20, 2008
Phaser 6110 factory reset?
NOTE: Print a Configuration Page before resetting NVRAM. Press and hold the [Up] arrow button on the Control Panel, and then press the [OK] button. This will automatically display the Service Tools menu on the Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Jul 06, 2014 | Xerox Phaser 6110 Laser Printer
Screen displays "printer error fuser temp"
Disassemble fuser unit and inspect thermistor and thermostat for dirt or damges, and heater lamp for damages.
Good luck.
Feb 08, 2011 | Xerox Phaser 3100MFP/S Laser Printer
There is no display on the screen.
if your display on your Xerox phaser 6350 is blank you should replace the control panel (part# 333-4424-00). It's a pretty easy fix, takes about 5 to 10 minutes to install. Here is a video that shows you how. Iteminc.com has this part in stock and ships same day. Hope this helps, and thanks for using FixYa!
Feb 02, 2011 | Xerox Phaser 6350/YDT Laser Printer
Can't read the display window on Xerox Phaser 8560
I have seen the same behavior on my 8560N. Sometimes the screen will be backlit, but the characters on the display are garbled. Other times, the backlight is off and the screen is blank. No manner of button pushing or tweaking the printer web server will bring the display back on. After a while, the display will just clear itself. I did not see this behavior until after I had a REALLY bad paper jam and some cardstock became lodged inside the print engine. I had to take the printer body panels off (which required disassembling the display interface. When I put it back together, everything worked, but the display started this strange behavior the next morning. Is it related? I don't know, but it sure was coincidental timing if not related.
May 18, 2010 | Xerox Phaser 8560MFP Laser Printer
The display on my 8560 Phaser no longer lights up or displays text in a mirror image when it does display. What could be the problem?
There is a known problem with the displays on the 8500 family of phaser printers.
Call 1-800-835-6100. Explaine the problem and they should send you a new display free of charge.
Mar 30, 2010 | Xerox Phaser 8500/DN Printer
Xerox 1235 a dot is going round and round the display
so sure you have a message on the screen please read it for me to help you
May 20, 2009 | Xerox Phaser 1235N Laser Printer
Printer error 15.004.45.433219 on Tektronix Phaser 860dp
Hi juniorgona:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850 and 860 have a pre-adjusted head.
Hope that this helps.
Apr 08, 2009 | Office Equipment & Supplies
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
We have a Phaser 8560 Printer and we are getting the message "maintenance kit low" message. What does this mean and how do we fix it?
This will require servicing:
The maintenance kit contains a maintenance roller that keeps the surface of the Imaging Drum clean and oiled.
NOTE: Order a new maintenance kit when the Display Screen displays a message that the maintenance kit is low. Replace the kit when the Display Screen prompts you to replace the maintenance kit. Both a Standard Maintenance Kit and an Extended Maintenance Kit are available for the Phaser 8550 and 8560; however, only a Standard Maintenance Kit is available for the Phaser 8500. An Extended Maintenance Kit will not be functional with the Phaser 8500.
WARNING: The printer's interior may be hot! Do not touch the hot surfaces.
Once you have the part: instructions:
  1. Open the door on the right side of the printer.
  2. Grasp the maintenance kit (labeled A) from the maintenance kit slot and pull the kit completely out of the printer.
  3. Insert a new maintenance kit and push the kit completely into the maintenance kit slot. Follow the illustrated instructions included with the maintenance kit for full installation and disposal information.
  4. Close the door.
This will be on the right side of the printer.
This will need to be replace every 10,000 sheets of paper.
  1. Close the door.
Apr 03, 2008 | Office Equipment & Supplies
Printer screen
Your display is blank because the LCD unit is bad and needs to be replaced.
Jan 10, 2008 | Xerox Phaser 8550DP Printer
164 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
