Question about Panasonic NN-S563 Microwave Oven
Panasonic NN-S563 no heat
After setting the timer and pressing start, the interior light comes on, the turntable revolves for about 30 seconds and then it shuts off. During the 30 seconds it runs no heat is generated.
  • TDLux Oct 20, 2008
    It makes no difference what power level i use or if i use a preset, it will run fo about 20-25 seconds and quit with no heat.
    Thanks for your help. This was confirmation of what I suspected. A whole lot cheaper and more convenient than taking it to a repair shop for the verdict.
    Thanks again.
  • 88 Answers
Most likely thing there may be a problem with the power settings buttons.as most of these are electronically operated.or loose or burnt connections to the circuit boards.or the switch that the door closes into may be faultywhen opening the door before programme finishes the switch cuts the power so it stops heating (safety device)i would recommend caution though as electricity can be dangerous.
Posted on Oct 20, 2008
  • 3,037 Answers
The magnetron has gone bad, not worth it to repair, go out and buy a new microwave. A $40-50 dollar one will last quite a while.
Let me know if you have any questions, just don't buy GE.
    Master:
  • 538 Answers
Hmmm...well..did you do a power setting? that is what is needed in the sequence just stated..try one of the presets like popcorn, to see if that works.
Posted on Oct 19, 2008
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Panasonic NN E225N all lights and no action It will start and light comes on and turntable revolves but nothing gets heated Happened once before and managed to get working again but don't know how Any...
Hi, it could be the magnatron (the part that actually emits the microwaves). This is supplied from a fuse and then a rectifier, so, it could also be one of these. If you said that it just started working again, then it might also be worth while looking for a bad (hot) connection within this pathway. Cheers Bob.
Mar 05, 2014 | Microwave Ovens
Heating ceases after one second
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
May 30, 2010 | Panasonic NN-H275 Microwave Oven
Will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
yysrsj
Sep 02, 2008 | Panasonic NN-S962 Microwave Oven
Panasonic microwave, model no. NN-A554W, bought November 2006. When I set the timer for say 3 minutes,the turntable only revolves for about 5 seconds, then stops. It has not been used very much since I...
This usually means that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 07, 2008 | Panasonic Microwave Ovens
Touch pad works but microwave doesn't turn on
NO the microwave doesn' t overheat or froze.
I couldn't answer to your question 100% because I don't know this model,
Some microwave don't heat if you don't set the heating temputer on, the power level. I've seen lot's of customer in the past couldn't get heat because all they press was time and didn't set the heat level.
second it is posible it doesn't heat because the magnetron power supply is burt out, this is the electronic board inside the unit below the magnetron, panasonic or know for burning this board to often, if it was I, they would have been design to inposible to blow them . Microwave have gone a long way and notice that the quality is not there no more. The old once or the same thing as the new once's but made more of plastic. The parts (main parts) or all the same design but mad to brake down after a shorter time. The older model lasted a minimum of 20 years, today they have the same magnetron but they don't last as long as before, made to brake. If they brake faster, the re sale or higher so more money to make.
To me it's just insulting to think that way, vehicule or the same , the repeat parts sales make profit go higher. It's all a tratege to make money faster and not respecting the consumer.
Third problem you may have is the magnetron is shut or the cap.
You would need a tech to tell you that part.
Regards
Bob
ps do what 99% think like trough it out, but make shure you understand you're creating polution everytime.
Jan 20, 2008 | Panasonic NN-S563 Microwave Oven
NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Dec 21, 2006 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-S563 Microwave Oven Logo
389 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
