Question about Singer 7422
Threader My singer is not very old,the threader worked 1 time,why is it not working?Thanks very much,kffrmw88@graceba.net
Try checking if the tiny hook is actually going through the eye of the needle. Mine wasn't and i bent it very gently with tweezers and now it works.
Posted on Oct 24, 2008
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
The automatic threader isn't working. the bobbin isn't sewing correctly?
make sure the bobbin is turned counter clock wise, also try changing the bobbin, also try a new needle. you may have to have the automatic needle threader checked to see why it's not working
May 20, 2016 | Singer Inspiration 4206
How do I change the bobbin winder on the Brother ls2125 sewing machine please
In the meantime, you can pick up a stand-alone bobbin threader at the local fabric store or online. They cost ~$25. A lot of sewists prefer using the stand-alone because it saves wear & tear on their sewing machine and they can also wind bobbins without interfering with the machine's setup.
May 03, 2015 | Brother Sewing Machines
I cannot get the CE-250 automatic needle threader to work. Threader and needle do not align up together.
Always make sure you rotate flywheel to raise the needle to its highest position before trying to use the threader. additionally the correct needle has to also be used so the threader wire and needle eye line up properly.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer Sewing Machines
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
My needle threader stopped working. It seems it is above the hole in the needed.
Mine too. the needle threader on this HIGH TECH machine sucks.! Couldn't they have done better.
I never got it to work consistently and now not at all, Don't know why.
Nov 28, 2010 | Singer CE-100 Futura Computerized Sewing...
I changed my needle on my singer 3116 and the needle threader does not work anymore. Hope you have an answer! Thanks!
It is probably out of alignment, just turn your needle threader so that the little wire goes through the eye of the needle and will catch thread. Also, sometimes the needle you put in has too small of a hole to thread easily with the automatic needle threader.
Oct 01, 2010 | Sewing Machines
Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Apr 11, 2009 | Singer Sewing Machines
Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Feb 07, 2009 | Singer 132QRFB Mechanical Sewing Machine
Singer 7422 Logo
78 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
