Question about Toshiba SD C2512 (SD-C2512) Internal DVD Drive
Toshiba sd-c2512 I am trying to update my laptop to an xp but the dvd drive sometimes work and sometime not, Help what to do?
  • Anonymous Nov 12, 2007
    Drive doesn't work all the time
  • Anonymous May 30, 2008
    toshiba sd c2512 dvd interno
Can this SD-C2512 write DVDs and CDs? Kindly answer this to pnsrao@gmail.com
Thank you.
Posted on Jan 30, 2008
My dvd rom will read a copied cd but not a burnt one. I don't know why.
It may be that it does not read either -R OR +R If you have Nero Info you can check the specs for
your drive or it might be just be a case of a bad cd try different brands .some brands don't work as well as others
Feb 12, 2011 | Toshiba SD C2512 (SD-C2512) Internal DVD...
I have the Same Problem, it can play cd/dvd that are already burn but if i put in a blank it say cant read from this disk
You can try to delete upper and lower filters for your system. go to start>run>type in regedit click ok> start looking for this parth HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318},when click on the folder look on the right column and look for upper/lower filters and delete it. restart system. Try updating the firmware of the optical drive depending on the model.
caution:be careful with deleting registry for your system this might affect your operating system functionality.
Jul 11, 2010 | Toshiba SD C2512 (SD-C2512) Internal DVD...
I upgraded to xp and since then my sd c2512 drive will not play dvd's and says there is no dvd software. Also I dont have the original boot disk, do I need to buy dvd software? or is there a download fix...
Did you buy this item as a notebook part, or did you buy another unit such as an external drive and take the drive out of it? If you took the drive out of another item, then you are going to have problems with the on board firmware. Toshiba is a nightmare for doing this.
Also some Toshiba computers do not allow you to upgrade the drive, even with a new Toshiba drive. I learnt this the hard way many years ago. At that time my new Toshiba Notebook would not recognize the New Toshiba DVD Drive, but my decade old Gateway Notebook did. I contacted Toshiba and they said they Firmware lockout new upgrades to encourage people to buy new computers.
Check out this link please http://docs.google.com/viewer?a=v&q=cache:c9ISyU6vpdkJ:sdd.toshiba.com/techdocs/SD-C2512userguide.pdf+sd+c2512+toshiba+driver&hl=en&gl=us&pid=bl&srcid=ADGEEShsjj8j7yHoKfKNT6WSziIQRAM6VrYCspnQVQsE9JfUGibulS7r56mXC9Raw11-oQRre2PKTOzHqPMNjEiJmEgT1ADYQg4KO1E0Q1BGuQnQJMUXV-HLHD21USz-qnEBQZYFhUyf&sig=AHIEtbQJ_Wvsgh01rmczXQxubYdYAl_Z6Q
Good Liuck.
Apr 24, 2010 | Toshiba SD C2512 (SD-C2512) Internal DVD...
DVd-rom replaced but not working properly
check the copyright settings on it, most dvd's have that so people don't bootleg it and re-sell it, check to see if there is any scratches on it, check for dirt, or take it to customer support and get a new one
Jan 28, 2009 | Toshiba SD C2512 (SD-C2512) Internal DVD...
Old DV-rom replaced and not working properly
do you have the software installed to watch movies ? and check dvd for scratches , and check lenses and everything on DVD-Rom
Dvd burner not working
It sounds like the DVD burner does not have a "write strategy" for the type of disc you are using. This results in the burner and the software having an endless argument about how to go about the burn!
You can either use another brand of disc more compatible with your burner or go to the DVD burner's manufacturer's website and check for "Firmware" updates.
The firmware is the software within the drive that establishes the write strategy for each type of disc and these are often updated.
If you do update the firmware then be sure to read the instructions on the manufacturers website carefully and follow them EXACTLY.
Jan 27, 2009 | Toshiba SD C2512 (SD-C2512) Internal DVD...
Need driver for 8x dvd drive for thinkpad
When a properly inserted and working drive is connected, it is automatically discoveredand installed. Specific drivers are not necessary or available. I will assume you are not talking about a DVD viewer application?
If the OS does not discover the drive, then the drive is likely defective, or not properly connected.
Oct 26, 2008 | IBM ThinkPad T20 2647 Notebook
Toshiba SD C2512 reading DVD but not Cd
solution for CD-rom problem: turn CW the second little potentiometer with a tiny screwdriver, just a little and try to read a CD, if it doesnt work then try turn the potentiometer again. the same solution for DVD-rom but with the first potentiometer.
Nov 12, 2007 | Toshiba SD C2512 (SD-C2512) Internal DVD...
Toshiba SD C2512 (SD-C2512) Internal DVD Drive Logo
304 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
