CTS 04, 102K miles, New Battery When trying to start the car, the dash lights illuminate as normal, but no cranking action occurs. When trying to remove the key, the key will not turn back to the home position for key removal. While the key is stuck in the ignition, movement of the the transmission lever out of park is not functioning. After removing the main battery connections for approx. 15-30 min, and then reconnecting, the key can now be removed. After removing the key, and then reinserting, the car can then be started without any problem. After several test stop and starts immediately following the battery disconnect / reconnect, all appears to be right with the world. After an undetermined time or perhaps complete randomness, the original symptom appears again. Thanks, Bill
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components.
• The automatic transmission shift lock control solenoid
• The brake switch
• The rear integration module (RIM)
• The transmission control module (TCM) or powertrain control module (PCM)
With the ignition ON, battery positive voltage is supplied to the automatic transmission shift lock control solenoid from the ignition 3 relay. The automatic transmission shift lock control solenoid is controlled by the rear integration module. When the rear integration module (RIM) receives a class 2 serial data message from the transmission control module (TCM) or powertrain control module (PCM) indicating that the shift lever is in the PARK position the rear integration module (RIM) grounds the automatic transmission shift lock control solenoid control circuit. This causes the solenoid to energize mechanically locking the shift lever in the PARK position. When the driver presses the brake pedal the rear integration module receives the brake applied signal and turns off the ground to the automatic transmission shift lock control solenoid control circuit. This allows the shift lever to be moved out of the PARK position.
Step
Action
Yes
No
Install a scan tool.
Does the scan tool power up?
YES - Go to Step 2
NO - Go to Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications
Turn ON the ignition, with the engine OFF.
Attempt to establish communication with the Powertrain Control Module (PCM) and the Rear Integration Module (RIM).
Does the scan tool communicate with the PCM and the RIM?
YES - Go to Step 3
Important: The engine may start during the following step. Turn OFF the engine as soon as you have observed the Crank power mode.
Access the Ignition Switch parameter in the rear integration module (RIM) inputs data display list.
Rotate the ignition switch through all positions while observing the ignition switch power mode parameter.
Does the ignition switch parameter reading match the ignition switch position for all switch positions?
YES - Go to Step 4
NO - Go to Power Mode Mismatch in Body Control System
Select the display DTCs function on the scan tool for the PCM and the RIM.
Does the scan tool display any DTCs for the PCM or the RIM?
YES - Go to Step 5
NO - Go to Symptoms - Automatic Transmission Shift Lock Control
5
Does the scan tool display any DTCs which begin with a "U"?
YES - Go to Diagnostic Trouble Code (DTC) List in Data Link Communications
NO - Go to Step 6
6
Does the scan tool display DTC B1000, B1004, B1007, or B1009?
YES - Go to Diagnostic Trouble Code (DTC) List in Body Control System
No - Go to Step 7
7
Does the scan tool display DTC B1327?
YES - Go to Diagnostic Trouble Code (DTC) List in Engine Electrical
This is something best left to the Cadillac dealer !
SOURCE: how to get key out that is stuck in ignition
Remove steering column shroud(cover)and tap ignition barrel with small hammer while twisting key backwards and forwards,also turn steering wheel backwards and forwards sometimes this is enough to release key as the locking pins in barrel and the steering lock pin do sometimes jam.You will have to remove steering column shroud to replace ignition barrel if tapping/hitting it doesnt work anyway so its not a wasted effort.Good luck,let me know how it works out
SOURCE: 2004 Jaguar XJR Shifter stuck in park position
the shifter cable is on the lift side of the transmission, make sure it is bolted to the trnsmission
SOURCE: can't remove key from ignition. battery is dead
If the battery is dead, the ignition keys will not release from the ignition. If there is no signal from the transmission shifter that it's in park since the battery is dead, then the ignition lock will not release the keys. After charging the battery or jumping the blazer to start it and the key's still will not release, try this.
There is a "plunger" as part if the ignition. Under the steering wheel there is a small removable cap that you can take off and put a small screw driver up into and press the plunger in and it will release the key. Good luck and hope this helps, Keep me posted be glad to help.
SOURCE: 1994 Saturn SL2 Key stuck in ignition cylinder
Put some pressure on the steering wheel in one direction or the other this may take the pressure off the cylinder itself and allow you to do what is needed...hope this works.
SOURCE: Key stuck in ignition. How to remove?
Ha this used to happen to me with my sunfire. Just wiggle the steering wheel while trying to wiggle the key out. Sometimes the steering wheel locks up and then keys will get stuck in ignition. Hope this helps.
