Question about Acer AL1911 19" LCD Monitor
Lcd monitor acer
There is no power at all.The computer itself is fine,as i have connected another old monitor up and its working fine.No light comes on whatsoever.
  • 513 Answers
Here is a similar post: http://www.fixya.com/problems-solutions/t103544,p154505/Liquid-Video-MVBG619-Portable-DVD-Player-with-Screen.aspx Post a comment if you think this is not your problem, or if it doesn't help at all.
Posted on Jun 25, 2006
SOURCE:
I have ac Acer S202HL LCd monitor. When I booted up one day it didnt come on.
first check with your both power supply out put is coming 19 Volts dc.
if its not coming check with multi meter primary and secondary of your adopter continuity.if no continuity replace with proper working adopter.
Nov 07, 2013 | Acer S202HL LCD Monitor
When i turn on my acer aspire it will not come on. The lights all come on but the computer itself will not come on. I have already tried the battery and charger. What's next?
It could be a issue with the display... If you have a external monitor try to connect the external monitor and check if the display is working fine in the external monitor.. If it works well you need to replace the LCD screen.. If its not working or you dont have a monitor it could be a hardware issue call up the computer manufacturer or get in touch with a local tech...
Oct 07, 2010 | Acer Aspire 4520-5141 Notebook
Help! My acer ferrari 20 inch monitor has worked perfectly for the year and a half I have owned it. Yesterday the screen just went blank.. no warning. I have checked all the cables and even plugged an old...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 01, 2010 | Acer Ferrari F-20 20" LCD Monitor
Acer LCD AL 1706 A monitor will not come on
The problem can be bad capacitors in the power supply, look for bad caps with bulging tops or seal, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further. To have it repiared by the repair shop will not be practical, est $60~70 repair bill.
Mar 11, 2010 | Computers & Internet
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Acer screen is black or blurry
If you've connected an external monitor to your computer and the image is coming up fine then that means your video card on the motherboard is good.
The only other parts it could be is the LCD Flex cable that connects to the LCD screen to the motherboard, the LCD Inverter that powers the LCD screen or the LCD screen itself. Usually you can find a used screen that is complete with all those components on ebay.
Jul 30, 2009 | Acer Computers & Internet
Input not supported
IT sounds like the monitor got fried.. sometimes if the monitor is in the on position as the power comes back, the monitor gets an unexpected sure which can sometime damage the circuitry. You may be out of luck. You're only other option is to try using the monitor on another computer to see if it's just a weird connection issue.
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Acer AL1911 19" LCD Monitor Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
