Question about Fisher and Paykel GWL11 Top Load Washer
Eco smart won't drain, smells hot
Washer shut itself down with a tub full of water/clothes. I restarted and it shut down again, with a little water leaking onto floor. Tried again in hope of draining the tub. It began to pump, but shut down and I smelled hot motor.
Have top off washer off, plastic tub ring off, and am inspecting area between outer plastic and metal tub and don't see anything in between. Tub moves freely.
What next? There are 3 screws in bottom of tub that hold agitator.
  • 5 more comments
  • HiRoller Oct 19, 2008
    Did not do anything more with the agitator or interior tub.
    I've tipped the machine back and I see what I think is the pump motor. The motor is black, is attached to the machine with 2 bolts (would be easy to remove), looks a little rusty and water is dripping from it. I am guessing I need a new motor.
  • HiRoller Oct 20, 2008
    Didn't do anything more with agitator/tub area except put it back together.
    I tipped machine back and looked underneath and could see that water was dripping from black motor area.
    I was able to unhook the 2 electrical couplers and unbolt the black electric motor (2 bolts) and pull it off. I could see that the area above the motor was still dripping/leaking and didn't know what to do next. errrr....waited for repairman.
    Repairman came and in about 5 seconds ($65 later) he unclipped the white plastic housing that is above the black motor. This white housing and the motor/fan come as ONE unit when you order the part. The leak is inside the white plastic housing--probably an o-ring. To unhook this whole unit, look for a white plastic clip that is attached to the machine bottom area. Simply push that with your finger and give white plastic housing/black motor a twist and it all comes off. Mine is 240V. Newer models are 120V.
    New part is on order and I can install it myself and plug in electric couplers. All FP parts come from California UPS ground. So, will be 4 more days without a washing machine. YIKES! So, I'm out an extra $65. Hope this helps someone else.
    See my comments with solution.
    Was looking at drain hole from tub that leads into the white plastic unit/black motor (part that is ordered) and noticed a lump of gunk. Turned out it was one of my husband's socks that had gone all the way to that point. I imagine this is what started all of my issues. I was able to pull the sock through that quarter-sized hole. Sure glad I got this out or I suppose it would have happened all over again as the sock wasn't going any farther and a new unit would have eventually leaked and burned up motor again.
  • HiRoller Oct 21, 2008
    In looking at other issues, I think I've been ignoring things for awhile that I see posted here.
    I had gray streaks on some clothes that couldn't be rubbed out. Only way to remove was to rewash.
    I could hear residual water in bottom of tub even after washer was done.
    There was a musty smell--due to residual water.
    I couldn't use the normal wash cycle--water was left in tub and clothes were soaking wet. only way to wash was to use heavy duty cycle so it would spin out more water and clothes in bottom of tub were still kind of damp.
    I think this was all due to the sock that was blocking the drainage tube.
  • HiRoller Oct 22, 2008
    Will do. Plan to check that connection to make sure no further leaks. Haven't picked up pump yet, but am guessing it will run over $100. Thanks for posting so this moved into the Solution section. Hopefully, it will help someone else and save them some $$!
  • Anonymous Mar 25, 2014
    Water enters tub area but then goes right back out of drain hose.
  • 46 Answers
Hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Posted on Oct 21, 2008
SOURCE:
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
Mildew smell
water may not be draining completely out cause something is stuck in drainage area.
Other posts tell how to remove the top of washer to look between white outer tub and inner wash tub for sock or something else that is lodged.
Look at my post on "eco smart won't drain, smells hot" for instructions on removing the black motor/white plastic housing from bottom of washer. I had a sock stuck in the very lowest part of the drainage system, water wouldn't drain out and couldn't see the sock until I removed the motor. I was able to pull the sock through the quarter-sized hole in bottom of tub and drain the remaining very stinky water. I used a dog dish (need a low edge bowl to fit under washer), tipped washer forward, then back and just kept emptying the dish.
Saw another post said don't tip washer back. There is something on backside of washer that you could break if you tip backwards. So, if you tip forward i guess you won't break anything--i haven't...yet.
Noticed a musty smell lately, and also had gray streaks on my clothes. Think the standing water that wouldnt' drain out has been my issue for some time now and when the motor burned out, I finally had to research the other issues.
Sep 20, 2008 | Fisher Paykel EcoSmart GWL15
Help
YOU NEED TO CHECK IF THERE IS NOTHING STUCK IN THE PUMP AS NOT DRAINING ALL THE WATER IS A SIGN THAT THE PUMP IS NOT DRAINING COMPLETLY.GOODLUCK. MOHAMED
Sep 18, 2008 | Fisher and Paykel IWL12 Top Load Washer
Water on floor under washer
re; water under washer.
The ammount of water is from 1/4 to 1 cup after an individual load. It only became noticable reciently, after the last 3 or 4 heavy loads, using the manual setting on next to the top level. There is an automatic function, but due to the dirt and grit in the jeans I use manual.
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
My washing machine stops mid cycle
issue where washer stops and water won't drain might mean something is in drain area.
look at my issue "eco smart won't drain, smells hot" and see about the sock. I found one of my husband's socks so far down in the tub bottom that I couldn't see it when I looked between plastic outer liner and wash tub. Had to remove black motor/white housing on bottom of machine--which i had to replace cause it burned out. That is when I saw the sock and pulled it out through a quarter-sized hole.
Jun 26, 2008 | Fisher Paykel EcoSmart GWL15
GWL10 US won't finish cycle
Hi Mate, I had the same problem and then looked on the web to find that all I need was a $40 out of balance switch. Although the old one looked ok it had corrosion inside, bought a new switch and installed it myself, easy, ask the F&P parts supplier if you are not sure.
Cheers,
Dan
Jun 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Broken washer
could be clogged drain. look at my issue "eco smart won't drain, smells hot" on how to remove motor from bottom of washer and check lower drainage area. bail water out first and be ready to catch water when you remove that motor unit.
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Washing machine not draining and finishing cycle
I had the same problem.... It would stop on the rinse cycle and beep.  Check to make sure you can hear the water pump running or if you can just hear an electrical hum and then it quits, it may be a problem with the water pump.The water pump can be accessed by removing the tub, reach down the center of the agitator and remove plastic bolt, remove the stailess steel tub and then remove the plastic oval shaped cover at the bottom of the main tub to access the pump impellor.  Make sure the impellor turns freely, if it does not you may have a problem with the pump motor.  We had a gold chain go missing and it showed up wrapped around the pump shaft causing it to bind at times.  It took me two tries to fix it but now it runs 100%.
Oct 31, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
1,126 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
