SOURCE: hp 2355 internal error
try to boot in safe mode windows,, and then uninstall the hp drivers,, and again install.
SOURCE: i have a hp psc 2355 printer everytime i insert
Is it the same memory card each time? If so, try with a different memory card.
If it's with all the different cards, verify that there is nothing wrong with the connector that the memory card touches.
-=/ Daft Tech /=-
I had the same problem with my HP L7590 All In One. After trying a number of
things to reset nothing worked. Then I tried this just as a last resort and it
worked.
Insert the/a memory card( it will tell you that you can only use one card at
a time).
With the card still in turn off the printer using the power button.
Wait for 30 seconds then turn power on again.
The screen should say reading card. So wait for it to finish reading and all
should be fixed.
If this does not work, try again using a different card.
good luck
Send me Kudos if it works.
